Old 02-20-2007, 08:48 AM
DaveinUK is on a distinguished road
Angry Boss 6 Axis Problem
Please Help !!
Slight problem with Boss 6. I switched it on this morning and in setup mode
both the X and Y axis move then stop, when stopped there is a buzzing noise. I can stop the buzzing noise by switching the function switch across to restart. Then the axis move again, but stop as soon as I take my finger off the switch, and the buzzing starts again. During this time the Z axis is not moving at all. I have checked all the transistors on the Z and they are OK.
Any Ideas ??
Dave
Old 02-20-2007, 03:20 PM
Gold Member
HillBilly is on a distinguished road
These are stepper machines so if a axis moves it is getting pulses in a quadrature fashion. I would suggest checking your computer power supply. DC voltage and AC ripple. If all is OK there I would check and reseat the boards.
Good luck,
Darek
Old 02-21-2007, 11:06 AM
Thank's Darek,
Can I find the thing's you suggest in the maintenance manual.
Dave
Boss 6 Z-Axis Pulley Identification / Problem snakebit95 Bridgeport and Hardinge Mills 17 09-04-2006 04:25 PM
Boss 9 z axis problem Drewboy Bridgeport and Hardinge Mills 4 03-28-2006 08:53 PM
Series 2 BOSS 6 Axis motion problem craig96us Bridgeport and Hardinge Mills 43 01-14-2006 12:06 PM
Boss 5 Y axis problem? jeaBOSS5 Bridgeport and Hardinge Mills 8 12-11-2005 04:40 PM
How To; troubleshoot an Axis problem on Bridgeport BOSS inthedark Bridgeport and Hardinge Mills 0 03-25-2004 08:35 AM
