Old 02-17-2007, 09:57 AM
smirob is on a distinguished road
Possible Purchase of R2E4
Hello,
I was hoping someone here may be able to give me some heads up info on a Bridgeport Series 2 R2E4. Specifically, I'd like to know how the control cuts, in DNC. I only ask, because we have a MX3 and 2 at the shop I work at, and if you let the control process the posted file vs DNC it, the machine actually pauses at every tangency in a 2D contour that you are cutting. Also, the placement of the control on the head is a bit different than what I'm used to. It has a BOSS 9 and EZ file and I believe it is around vintage 1985. Wow, I just realized that was the year I graduated HS . In any case, I've got no practical experience with either, so any tips of do or don't in my expectations would be welcomed. For instance, will I be screwed in file size that I can post to the machine?
Finally, I'm not sure of the power requirements, but if this is a 208 Volt, can someone point me in the direction of a source to re-power it?
Thanks In Advance for the help,
Rob
Old 02-18-2007, 04:07 PM
jeep534 is on a distinguished road
not being a pain but click on search and type R2E4 and click go. that should give you a start. also these machines are getting old and the controls and front control pannels are getting fragile as well as a bunch of stuff the people are talking about those post's that you will find after you search
happy hunting
archie =) =) =)
Bridgeport R2E4 steve ohalloran Bridgeport and Hardinge Mills 11 06-21-2010 04:11 AM
R2e4 steve ohalloran Bridgeport and Hardinge Mills 2 02-18-2007 02:02 AM
R2E4 Help jeep534 Bridgeport and Hardinge Mills 2 10-14-2006 12:45 PM
Quircky R2E4 AlSi Bridgeport and Hardinge Mills 9 02-17-2006 10:37 PM
bridgeport 9 r2e4 reedmiles General CNC (Mill and Lathe) Control Software (NC) 0 12-30-2005 09:06 AM
