To all those interested, I recently purchased some NMTB- 30 tool holders through MSC. They are made by Accupro and priced from $47 - $57, in sizes from 3/16" to 1". The only issue I have found is the flange diameter is about .140" to large which can easily be ground down to fit the nose cap of the spindle. Steve |
| Can you provide some part numbers? I did a search on the MSC site, and could not find any NMTB 30 stuff. How hard are the holders? Think you can turn the flange O.D. on a lathe instead of grinding? Thanks, Wayne |
Page 1567 for DA holders Page 1580 for boring head shanks Page 1584 Morse taper adapters Page 1585 for EM holders I have a V2XT that uses these tools. I have a place locally (near Boston MA) where I buy used EM and DA collet holders for $20-25 each. All Erickson. NEATman |
| Newby2, I did not see any Accupro for the price range you listed. I think you may have ordered the standard import; which has that $40-$60 range. NEAT, Thanks for finding them. Sounds like you are getting a great deal on the used Erickson holders. Does the place near Boston have a webpage? |
| Snakebit http://www.brothersmachinery.com/ You'll need to call about the toolholders. The only reason I'm sharing is that I have all the toolholders I need ;-) - Got real lucky at work - They tossed a complete new set of NMTB 30 toolholders & it even has the R8 adapter also. Does anyone need an R8 adapter for NMTB 30? Also, if anyone needs BT35 toolholders let me know. NEATman |
| Guys all of the import holder I have tried would not work in a QC spindle. Yes you can turn down the outer diameter but the guage line from the taper to the top of the flange is too short. The nut will not tighten down.If you have any extra Erickson's I would be interested. (;-) TP |
| I was under the impression that J&L bought out the Erickson line, and now sell it under the Kennametal name. Admittedly, I haven't bought any tool holders since the name change, but I note with interest the linked page from the J&L web site: http://catalogs.shoplocal.com/jlindu...agenumber=1142 They call these "30 QUICK-CHANGE (NMTB)" and are available from Kennamental and Hertel. The next page shows what the call "30 NATIONAL STANDARD TAPER" tool holders, which have a different gauge length, and are available from Hertel and "Value Import". Note that Herel has different part numbers in each list, so these are indeed different items. They also still show the DA collet chucks as "30 QUICK-CHANGE" on this page: http://catalogs.shoplocal.com/jlindu...agenumber=1184 Kennametal brand only. Pricey, but still available. Dennis |
#11
| Found these in a clearance brochure sent to the shop. If the nut doesn't seem to work, remove the nut and use a 1/2-13 drawbar. The tool holders are quite hard, and with the nut removed and a drawbar used, they can be ground to size right in the spindle with a little injinuity. As for the gage line to the face, remove the 2 setscrews in the cap and they should tighten and work as normal. Steve |
#12
| I have 2 mills with NMTB 30 spindle's in them. I also have a NMTB30 to Erricsson 30 quick change (which the hub is smaller) so my assertion is that a Erricsson quick change 30 will work in a NMTB30 spindle not the other way around. archie =) =) =) |
| How to change Tool change position(About MAZATROL T1 control) | liushuixingyun | Mazak, Mitsubishi, Mazatrol | 5 | 07-07-2007 03:58 PM |
| NMTB 30 tool holder or ER collets in adapter? | acerocket | Bridgeport and Hardinge Mills | 2 | 08-09-2006 10:45 PM |
| Kwik Change 300 tool holders | johnd | General Metalwork Discussion | 5 | 02-27-2006 03:27 PM |
| Quick tool change | Biggermens | CNCzone Club House | 5 | 02-02-2006 12:36 AM |
| Quick change tool system (milling) | mark c | General Metal Working Machines | 3 | 02-17-2005 07:50 AM |
