Old 02-10-2007, 12:51 PM
markhas is on a distinguished road
BP S1 Boss4 questions
I am a relative newbie. I have a BP series 1 ridgid ram using the Hill Billy board and Mach 3. The control works well. I have a few mill related problems that I would like some help with
1) There is significant (.020) play in the ways on my table (along the Y axis) under heavy cutting load. Is it common for these to need to be tightened?
2) I have pnuematic spindle lock on my machine. It works, but it is always "ON". I have the bridgeport manuals and I looked at the pneumatic diagram, but I can't tell how the solenoid valve gets energized. Can someone let me know where the power comes from for the air solenoid? Is it wired through the E stop?
3) I have mechanical speed control, and it does not seem to change the speed at all. Also, when I put it into "high" speed, there is very little power coming out of the spindle (too tool stalls easily). Is this a worn belt or other issue?
Thanks much!
Mark
Old 02-11-2007, 10:35 PM
Moderator
machintek is on a distinguished road
I have to find a schematic but if you have one, it may be wrong. Some machines had a manual brake. Some had the electric brake. On a modified machine, all bets are off.
George
Old 02-12-2007, 06:31 AM
Gold Member
HillBilly is on a distinguished road
This shows the brake option.
If you had to rewire your machine transformers from 480 to 220 volts, the spindle has to be reconnected for 220 also.
Darek
Old 02-12-2007, 08:31 AM
George and Darek,
Thanks for your replies. Here are a couple of pix. From the schematic, it looks like that there should be a brake switch. I don't have one, so I am guessing that I don't have a factory pneumatic brake. I traced the air lines back to the transformer cabinet, so I'll have to start there.
Good catch on the motor, I don't think I ever rewired it for 220/3ph. Thanks!
Mark
ID:	31534   Click image for larger version
CNC mill questions - thrust bearings, leadscrew mounting, general questions tonofsteel DIY-CNC Router Table Machines 8 02-03-2012 04:42 PM
A few questions on FC2.5D Edster FeatureCAM CAD/CAM 4 11-12-2006 09:00 PM
Questions about TIG jrc347 Welding, Brazing, Soldering, Sealing 8 11-10-2006 10:40 PM
IH CNC Questions krymis Industrial Hobbies (Support forum) 105 10-26-2006 11:49 AM
Using Boss4 code in Boss9 machine pcsimp Bridgeport and Hardinge Mills 2 03-21-2005 08:56 AM
