i have a 3 axis eztrak that works beautifully except 2 things , when i reboot and home the axis my Y axis zero point changes usually .100 in plus or minua direction , the other problem is with the Zaxis sometimes the z zero point changes while the z axis drifts down and th z zero point changes while the machine is on. thanks r brinttle |
| Y axis: move home switch "dog" so the switch makes .030 inches sooner. Your marker pulse and home switch coincide. Does your Z axis motor have a rotary encoder? This means there are 2 cables coming from the motor, just like the X and y axis. George
| That is why Bridgeport mandated that the dealer retrofit these machines with a motor/encoder unit and the associated parts such that it DID not rely on the glass scale when in 3 axis mode. The glass scale would mis-read and the Z would adjust its position. Not good. George
| You need to contact Hardinge. Will they do anything for you is doubtful but you can try. The kit we used included a new motor, new AXSBOB board, cables, etc. It was not intended for the old style 3 axis with the ball screw on the left side of the head, but for the newer style with the Z ball screw in front of the quill. Like I said, a dealer may have dropped the ball here. But Bridgeport only paid us for about one hour of labor when we had travel expenses and the conversion took closer to 4. I can understand that other dealers did not want to do this. You could make sure that the reader head is properly aligned to the scale and not loose. That may help you. George
| Make sure the coupling to the quill stop eye lug and encoder head is snug, as well as all other fasteners to the encoder scale mounting. I'd suspect any float in the Z encoder feedback verses actual position or hunting, should directly relate to poor mechanical rigidity from the quill to the encoder. The cast arm that gripped the quill low could cause similar nonlinear tracking of commanded verses actual position also. At least some possiblity among many. DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
| ez-trak | rsbbmw | Bridgeport and Hardinge Mills | 6 | 06-07-2007 03:08 AM |
| V2XT Y axis drift | Spin | Bridgeport and Hardinge Mills | 2 | 12-23-2006 04:37 PM |
| Drift Problems - Possibly EMC Config? | eeboy | LinuxCNC (formerly EMC2) | 2 | 05-15-2006 10:08 AM |
| EZ-Trak Plus | DWilliams123 | Bridgeport and Hardinge Mills | 2 | 04-28-2006 07:28 PM |
| Z axis drift | IainLGrant | Benchtop Machines | 1 | 03-12-2006 08:56 AM |
