Old 02-07-2007, 10:59 AM
cncnavy is on a distinguished road
V2XT Software Startup
Alcon
The B-port V2XT we have has been working okay with the original
BossXT software floppy but for some reason I'am now getting the following error at startup, NTDLR missing. I've tried several backup software copies
but get the same error. Anyone run into this before.
Old 02-07-2007, 04:26 PM
NC Cams is on a distinguished road
Check the floppy drive to see if it is still functioning properly. Consider replacing with a TEAC if it went bad as these have been the most trouble and read problem free FDD that we've ever had/used.
Check the FDD controller card for same functional capability and operation.
If your FDD has gone bad or is flakey, plan on replacing the motherboard - when we lost our FDD card, the M/B went south shortly thereafter.
Old 02-08-2007, 01:04 PM
NC Cams
Thx for the FDD info & I'll change out the F Drive 1st & see what happens.
I know this has probably been asked but how do you get the machine to boot up from a hard drive. I installed one but no luck on the boot up.
Old 02-08-2007, 02:45 PM
IF yours is an FMDC based controller, I'm pretty sure that it can/will ONLY boot from a floppy.
IF it is a BMDC based DX-32 system, it should be bootable from the HDD if you have the BIOS properly set to look at the C:\ drive for the boot sector of the software.
You might be able to write a batch file to get it to boot from a HDD if it is a FMDC but I'm not literate enough in FMDC speak to tell you how to do so. Perhaps a friend who's DOS literate can help you figure out a way.
Old 02-08-2007, 09:25 PM
Moderator
machintek is on a distinguished road
Sounds like a FMDC based control. The BMDC versions had a hard drive. If this has the original mother board, it is now possibly 17 years old. WOW!
The CMOS may be set incorrectly for the floppy as well.
George
Old 02-16-2007, 01:51 PM
Alcon
I changed out the FD & the program is now attempting to load from the
HD. The program gets all the way to the machine check part & then I get the following error, run-time error R6003
-integer divide by 0
C:\>
We're making progress
Old 02-16-2007, 04:11 PM
Check your CMOS settings (usually reachable by hitting DEL key while boot sequence is executing)..
If the CMOS has gotten corrupted or changed by malicious code, your system will try to boot from the HDD instead of from the the A:\ drive or wherever the software wants/needs to boot from.
Old 02-17-2007, 01:47 PM
RichWood is on a distinguished road
My V2XT (FMDC version) came with a 720KB floppy. I later swapped if for a 1.44 floppy with no problems. I then added a hard drive (MFM type) with the cables plugging right into the 286 motherboard. That worked OK too after setting up the CMOS. The last note inidicates that the PC is booted and BXT is up but getting a problem when trying to talk to the FMDC. How did BXT get on the hard drive (C:>) and is it a valid version compared to the .HEX that is in the FMDC? Also, NTLDR seems like a Windows startup. Are you running DOS or WFW?
Old 02-17-2007, 05:31 PM
Moderator
It may be a bad FMDC or a bad com port to the FMDC.
George
Hurco BMC 20 startup problem tirebiter Machine Problems, Solutions , Wireless DNC, serial port 3 11-08-2006 05:50 PM
V2XT startup fail error-1 photoron2 Bridgeport and Hardinge Mills 11 10-05-2006 12:21 PM
Need some startup advices... b_cybe DIY-CNC Router Table Machines 15 03-16-2006 05:18 PM
mastercam startup problems sixthearl Mastercam 5 01-31-2006 11:20 AM
V2XT startup issue V2XTnewbe Bridgeport and Hardinge Mills 11 06-07-2005 02:26 PM
