Old 01-28-2007, 03:02 PM
TPMX is on a distinguished road
Head Removal On Series 2 Cnc
I have my new toy home after 600 miles going to get her.Its a very nice condition Series 2 cnc rigid ram.
My next project is to get it in through a door that is 6" too short.
After reading through the manual it looks like the best course of action is to remove the entire head/motor assembly.Looks like the wiring, stepper,lube line and 4 bolts it looks like the whole unit will come off.The manual shows a diagram
for a lifting bracket with a loop that bolts on top with 1/4-20 bolts to lift the entire unit off.
This will provide tons on clearance and less dissasembly than other ways.
What do you guys think?Anyone ever pull the head assembly off?
The machine is in such good shape I just want to take my time getting it unloaded and in the shop.
I borrowed a 12ton trailer and used my Silverado 2500HD to tow ,the trip went excellent just take your time and its not bad at all.
Old 01-28-2007, 05:32 PM
colin1544 is on a distinguished road
series 2 cnc head removal
Hello sounds like you got a good buy I have a series 1 and have moved it six times in the time I've had it its an easy job if you are careful and you have the head room to get a set of chain lifting blocks in place if you make the lifting bracket as described in the manual it lift's nice and level. To start I removed the cover over the Z Axis drive and slacken the motor screws off so as to allow the timing belt to be slipped off the motor pulley, remove the front cover on the head that house the limit switches that control the Z Axis remove the screws holding the limit switches leaving the wires connected remove the box that houses the emergency stop switch and spindle direction switch on the right hand side of the head casting support the box and feed the switches carefully through the cast hole in the side of the head and then support the whole of this together on the side cabinet I then took off the Z Axis stepper motor still with the wires connected and strapped it onto the cabinet at the back the only wires I disconnected was the main spindle drive motor. Now comes the tricky bit take the bridgeport plastic side covers off the rigid ram and feel for the oil feed pipe that goes to the quill pull it out carefully through the sides cast holes in the side of the rigid ram casting hopefully with enough spare pipe you can then use something convienient to hold the end going down to the base colum and out to the bijur oil pump cut the pipe making sure that you anchor the end that goes down to the base casting and fit a 4 mm compression or push on air fitting this is used to reconnect the oil pipe together on reassembly tie this off to make sure that it does'nt drop down inside if you do its hell of a job to get at it as you have to remove the back cabinet and get in through the small access in the base casting to get your arm in to feed it back up to the top to reconnect now with the side covers removed and the switches outside and left dangling the Z axis motor off clamp the lifting jig in place connect a D link through the eye bolt on the lifting jig and use your lifting tackle to just take the weight you are now ready to remove the 4 x 1/2" allen screws that hold the head on I know the set up look's a bit weak using just 3 x 1/4" x about 11/4" long unc cap screws to hold the weight of the head but I assure it's quite safe it weighs altogether about 400 LB's remove the 4 retaining screws with someone helping just to steady the head while you get ready to take the lift just bring the head forward slightly and make sure you can hold the lubrication pipe and feed it through clear of the ram and taking care that you don't kink it lift it clear and get it down of the ground, to protect the quill in the ram from getting dirt on it I alway's put some clean cloth's in the opening at the back of the head till it's ready to be re-assembled any dirt or grit will damage that nice Chromed Quill now you can move the machine into place . Re-assembly of it all when you get the machine place is just a reverse of what you have just done there is a gear on the back of the head which is used in conjuction with the adjusting worm for adusting the head using a D T I set as wide as possible to make sure it's all nice and square to the bed take time to get this correct the accuracy of your machine depends on it all being nice and square .I hope this helps it's not as bad as it first looks just take your time with care. Cheers Colin.
Old 01-28-2007, 05:38 PM
Hood is on a distinguished road
I have a series1 rigid ram, got it through the door that was 4" too low by lifting it with one fork of a forklift on the lifting eyes then attaching a ratchet chain hoist to the other fork and down to the back of the base. Tightened up on the ratchet causing the mill to tilt over, got it through the door and then lossened the ratchet and placed the mill down on rollers for final placement.
Hood
Old 01-28-2007, 07:17 PM
Thanks for all the info.I am going to give it a try as soon as I get a break in the weather,i'm in Ohio and its cold here now.The mills still on the trailer oiled down and tarped good.
I was wondering about the oil line I will watch out for it.I am not sure about the gear you talk about.Is this on the solid head or just 1 that tilts?
THANKS AGAIN
Old 01-29-2007, 04:54 PM
head removal
Yes the gear is on the fixed ridgid ram type but is only a limited movement not enough to lower it down by six inches it's the main spindle motor that stops it Cheers Colin
R8 spindle pin removal krymis Industrial Hobbies (Support forum) 37 01-08-2007 07:42 AM
Bridgeport series I head ?'s toolndie7 Bridgeport and Hardinge Mills 1 12-30-2006 10:27 AM
tm-1 handwheel removal? superrat Haas Mills 6 11-10-2006 09:52 AM
Quill removal HOSS Tree 2 08-08-2006 06:21 AM
bridgeport series 1 steppers heatsink removal andrewbishop66 Bridgeport and Hardinge Mills 2 11-15-2005 02:00 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
