Old 01-21-2007, 09:57 AM
camarogod98 is on a distinguished road
HELP...interact 4 lost parameters
I just bought a series 2 interact 4....got it home and powered it up and the screen is all in german and its asking for parameters before i can do anything else with it to see if everything works on the machine.
I know some of you guys have them because i remember reading about someones interact 4 that needed them to all be reloaded. I replaced the 3 AA batteries in it already.
Could one of you guys please help me out...I cant play with my new machine without the parameters loaded in.
heres my email Camarogod98@hotmail.com
Old 01-21-2007, 01:24 PM
ibwood2 is on a distinguished road
I had one of those once, with the same problem. Forget about the batteries and get a UPS from your local office suply computer shop and wire the controller to it. This is fairly easy and will give a more reliable memory backup. The manuals are available in PDF format from Heinenhein and should get you out of trouble.
Old 01-23-2007, 02:52 PM
gus gus is offline
gus is on a distinguished road
the batteries last about ten years, you do the math
heidenhain can get you a generic parameter list, but I don't know how has the real list, I thought hardinge didn't support them
Old 01-23-2007, 08:08 PM
Moderator
machintek is on a distinguished road
I sent you a generic list. Did you not get it?
George
Old 01-24-2007, 09:36 AM
You must be as smart as you think you are. The batteries MIGHT last ten years if the switching circuit is ok on the CPU board. The UPS works either way and provides a well filter electrical power to keep your chips and such happy. The unit we had would last about twenty minutes on a new set of batteries. The UPS kept everything in for two years, maybe longer, we sold the machine, so I don't know how it's doing now. I have the technical manuals in electronic format and a list of parameters for our machine, if anyone needs them.
Old 01-24-2007, 06:03 PM
That you for the parameters that you emailed me. I typed them in the control and she powered up just fine. I just wanted to start the control up to see if everthing worked correctly before i do a retro. Im going to sell all the electronics off of it to one of the guys on this forum...
Old 01-25-2007, 02:11 PM
gus gus is offline
re
excellent, you oughta try running it as it is tho, if its at least a 151 it is a full 3 axis control and will run perty nice
re: batteries, dontcha think ya oughta fix the problem rather than add complexity?
I have 3 of the smaller heidenhain controls and they all get at least ten years
Old 02-07-2007, 01:41 PM
ronmarkum is on a distinguished road
I recently replaced the handwheel on our series 2 interactII. During the process we lost the parameters but were able to reload a copy we had stored for such an occasion. However, not the controller only speaks in German. How do you get it to back to english? Is there a menu command or a machine parameter that needs to be reset?
Ron
Old 02-07-2007, 03:36 PM
gus gus is offline
re
which control?
151 is no 92, mine is 0, 3 might also make it english, but with a decimal point not comma, or something...
Old 02-07-2007, 03:55 PM
Sorry I didn't include the control. It's a 150.
Changing para92 to 1 did change the comma to a point, but still German even after a reboot of the machine.
I seem to remember a screen prompt that allowed the user to change languages... but I can't read the prompts anymore???
Ron
Old 02-07-2007, 05:34 PM
Moderator
It is a parameter but I need my control book at the office to figure which parameter it is. By the way, using a decimal point instead of a comma creates its own issues. Some canned cycles do not work because they expect the commas.
George
  #12   Ban this user!
Old 02-07-2007, 08:09 PM
gus gus is offline
re
see, not 1, 0 or 3 or add 2 to err, something. the comma/decimal and language are handled by the same parameter,for some reason
Bridgeport Interact 520/Heidenhain TNC 155 initial parameters jeromir Bridgeport and Hardinge Mills 10 08-30-2010 05:01 AM
Lost parameters darrylh Fanuc 15 06-09-2010 02:02 PM
Lost fanuc 3T parameters erikturn Fanuc 6 01-30-2009 04:30 AM
Interact 412 code Bridgeport and Hardinge Mills 3 02-01-2008 08:36 PM
Bridgeport Interact 412/Heidenhain TNC 250 initial parameters pedrow Bridgeport and Hardinge Mills 11 04-04-2007 12:09 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
