Old 01-20-2007, 09:32 PM
Mark Kraus is on a distinguished road
Brideport 2 x and y working. Z ?s What tool holder? Kenametal qc nut #40
IN 7/2005 I wrote about my project bridgeport series 2 nc with 4 hp head. Tonight I got x and y working with gecko 202 and cnc4pc bo board and mach 3. I had turbo cnc and had it working a year ago then my computer crashed and I bought another windows 98 to run it and it didnt work. I just about gave up. Then I tried mach 3 on my laptop compaq r3000 amd athlon 1.9 gig hz xp and it moved some but terribly. unuseable. Then i got a pentium 3 1gighz xp desktop and it works great. In the process of trying to figure out all the problems I bought three new motors and Installed one of them. IN the process of taking the one off I used the mounting pllate from the motor and trashed the motor. Now I know the motors were not the problem at all. Anyway I really feel like I know this cnc from front to back now because of all the trouble Ive had. I never did get the z powered up because I was not sure how to tell if the pnuematic cylinder was working or not and what air pressure to use. I know that from your answer on a previous post You know alot about these machines. I trashed the tower that went with the machine. I stilll have the box on the back. I did not touch much inside. I would like to know what voltage the bijur oil pump is and ac or dc I dont know how complicated it would be to computer control it or maybe just have a button to pusle a few seconds. What are your thoughts. One of the main questions I have is what tool holders fit this machine? It has a kenametal qc 40 quick change nut and no drawbar. I have bought some nmtb 40 holders and they dont work with the nut althougth I believe the taper is correct. I can sendn a picture of the spindle opening and the nut. I also removed the spindle wizard. Is it rack and pinion inside that makes the spindle move? Would it have enough accuracy to atatch a pulley and stepper motor to move it up and down. Would it be worth it since the table already moves? If you like instead of typing I just learned about skype it is a voice over internet thing all you need is a mic and speakers or a headset. Thanks in advance for any thoughts you have. Also what do you think would be the maximum ipm on this machine. I already tuned the motors in mach and I have not gotten the stop watch out. My power supply is 56 volts taken from the old tower. Could I increase my speed with more voltage to the drives. Ps the old motors perform as good or a little better than the keling NEMA34 HIGH TORQUE STEPPER MOTOR 1160OZ-IN. With using inches and 2000 step units My maximum velocity is 450 and 100 accel without missing steps. Are there any other ways to tweak the mach system? Mark Kraus 704 637 0360 salisbury nc
ID:	29996   Click image for larger version
Name:	Mill Bridgeport (11).jpg‎
ID:	29997   Click image for larger version
Name:	Mill Bridgeport (12).jpg‎
ID:	29998   Click image for larger version
Name:	ebay P (1).jpg‎
Name:	Camping trip 046.jpg‎
ID:	30036   Click image for larger version
Name:	Camping trip 047.jpg‎
Old 01-21-2007, 04:25 PM
colin1544 is on a distinguished road
series II bridgeport
Hello Many years ago I had one of these machines and found it to be very good I am suprised that you took off the spindle wizard as I found that once I had got rid of the air leak problems it proved to be very useful and accurate because you have obviously not tried the Z axis drilling cycles they were available in the old boss control system but to see the knee going up and down in rapid when doing a drill cycle with peck is quite frightening. and although it will do very accurate drilling it puts alot of stress on the screw and air assisted cylinder and yes I suppose you could put a stepper motor on the quill feed but you would probably have to set up the backlash compensation on it dependent on the wear on the quill rack If I remember correctly if the air was turned off the system would not run as it protected the drives trying to move the knee as without any air assistance it would burn out the drives to the stepper motor so if you do turn the air off and your knee gets very heavy to move then this will give some indication as to the air assistance you are getting and the state of the seals also without air on if left overnight without the knee clamps on the table would fall under its own weight rotating the ballscrew as it went down but this also gave another indication as to the condition of the seals on the air assist because another way was to put a ball stop valve in curcuit and turn this off at night as well again testing for air leaks. the spindle on mine which looks the same as yours was a bristol Erickson quick change using 40 international size holders I have some of these which came from off a Series II BTC machine and although they have the pullstud built into them it didn't matter as the flange gage line was the same and also has the same flange locking dimensions i have just re-read your post and realised I missed some points out that you queried if i remember the lubricating pump is 110 volts AC and was connected inline with the spindle contactor so that when it was running it pumped oil around the system it also had a float switch in line also again as safety point for the machine so as not to be able to run it without oil it stopped the spindle from being started and also the program from continuing and although I have not had a look at the outputs on Mach3 I would have thought that it could be linked into the safety curcuits. But all in all my machine was old but had a very useful large bed movement and I wish I had the space to put another one in my garage. Best of luck Colin
Brideport Drawbar smart323232 Bridgeport and Hardinge Mills 4 06-15-2006 12:43 PM
Help! Bridgeport Series 1 CNC Y travel not working jairosoft Bridgeport and Hardinge Mills 3 05-25-2006 04:18 PM
Value of series 1 BOSS w/working modern CNC conversion? SRT Mike Bridgeport and Hardinge Mills 0 12-10-2005 10:47 PM
Brideport to CNC ... do you copy zoeper Servo Motors and Drives 9 12-09-2004 03:31 AM
Brideport Drive pin? ty1295 Bridgeport and Hardinge Mills 3 11-15-2004 07:56 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
