Old 01-10-2007, 10:33 PM
gbarker is on a distinguished road
BridgePort Series I CNC BOSS 9 / R2E4 Problems
One problem is that it boots up with a corruption in the program memory, but I can clear the program/macro and all is ok there.
If I try to bring of the FIST log, it comes up fine.
If I try to bring up the BOSS log, it comes up with corruption, list the corruption for a while then BOSS dies. If I have the 232 cable hooked to port A, it dumps some info there. This isn't a big deal either, if I just don't look at that log.
The real problem is downloading a program, I have been trying, and it keeps showing corrupt data there as well. The cable seems fine since I can communcate with the debugger on port a, but when I try downloading on port b, it stops instantly says 0 character sent, and stops. Sometimes with corrup data in for the program, usually with nothing though.
I'm assuming all my problems are with the BSP board in studying the manual, does anyone else agree. Should I remove all the chips, clean them and re-install them, some show sines of corrosion. I've removed the circuit boards, cleaned the connectors with circuit cleaner and an eraser.
Is it possible that I'm just missing something on the download to the machine, I'm starting and ending the code with a % sign on first and last lines. Sending at 4800,7,e,1 x-on/x-off, 1ms line delay, and I've checked the baud rate in the options from the front panel.
I have all the manuals, but none of the bridgeport software, if anyone can send me the bridgeport download programs I'd appreciate that.
In running some of the checks from the service manual, I have found several voltages out of wack, but given that most things work, I'm not sure what to make of it.
The 90volts from T1 is reads much higher, and the 24volt supply reads about 36. I can't really figure out why the transformers would put out the wrong voltages. ( I recently moved the machine from my house where it was running on a rotary phase converter to my shop where I have it hooked to 3-phase, prior to moving it it wasn't use for about the past 1.5 years. )
Can anyone help me figure this out.
Granville Barker
Old 01-11-2007, 07:09 AM
Moderator
machintek is on a distinguished road
Check the 4 AA batteries first.
6 data bits, 2 stop bits, X on, X off enabled , no parity.
Port B for EZLINK only.
George
Old 01-11-2007, 02:06 PM
I just replace the batteries so they are good. You say port B was for EZLINK only, but I am sure that's the port I was using before to load from bobcad/cam.
Any other ideas, I've got a few parts I want to cut, but I don't want to think about entereing the g-code from the front panel.
Thanks,
Granville Barker
Old 01-11-2007, 03:23 PM
Can someone send me EZ-CAM II?
I wanted to see if it would talk to EZ-CAM II, that's the program that comes with the bridgeports isn't it?
My email is <my last name> at gobarker.com
Thanks in advance...
Granville Barker
Old 01-11-2007, 08:08 PM
Moderator
Sorry, 8 data bits.
I purchased my BOSS 9 in 1986. I used a Radio Shack TRS80 Model 100 to edit programs through port A. I used a EZCAM based on the Apple Mac to transfer programs through port B using EZLINK.
Corruption of data is not good. It may be memory going bad. I do not think it is the EZIO board (bit maps the CRT and stored 16KB of program_trunkates the rest) as it displays some things correctly. Fist event log comes from the FMDC. I wonder where the BOSS event log comes from.
Bridgeport supported EZCAM. The rest were competitors and ignored.
George
Old 01-12-2007, 10:18 AM
It looks like Boss comes from the BSP board. I'll look at it agian to see what static ram chips I see on it. I've got a lot of old hardware around, I may be able to scrape up some more RAM chips for it.
I read the manual last night on using edit mode with port A, as I've never used that before. I'll give that a shot today to see if I can enter a program that way.
I only want to make 3 small parts, and if I hand-code it using the canned bridgeport profiling, boring, and drilling routines, I can probably get it down to a page of code. Too bad Bobcad doesn't generate code using those routines...
What do you think about the 36 volts on the 24 volt supply?
Old 06-17-2010, 02:56 PM
woodduece is on a distinguished road
I need 1 servo for a Bridgeport R2E4 Cnc anyone have a spare?
Old 06-17-2010, 09:56 PM
Moderator
Servo motor or drive? What is the part number on the one you have?
George
Old 06-18-2010, 05:51 AM
Model number 402cnsp0s72 powertron brand
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
