Old 01-09-2007, 03:48 PM
Sperstad is on a distinguished road
Change motor on a Bridgeport machine?
Hello
I`ve been planing to buy me a used Bridgeport machine from the states now. But since almost all Bridgeport machine only can handle 60Hz current, and not 50Hz, this may bee a problem. Here in Norway we have 230v and 50Hz.
But I thought that, if I buy a machine from the states then I can change the motor with one that can handel the 230v 50Hz. Are the engines on most Bridgeports very standard physical (outside the housing) if you know what I meen? I was thinking on how easy it is to mount a motor from the aftermarket. The type of Bridgeport machine I`m planning to buy, is one like this:
http://cgi.ebay.com/ws/eBayISAPI.dll...ME:B:WNA:US:12
What do you thing about a motor conversion on a machine like this?
Old 01-09-2007, 03:55 PM
gridley51 is on a distinguished road
Why not buy one of www.ebay.co.uk
Correct voltage and a lot cheaper to ship.
Mark.
Old 01-09-2007, 03:57 PM
Al_The_Man's Avatar
Instead of changing the motor, you could fit a VFD (single phase in-3 phase out), you would need a Phase converter anyway, unless you have three phase 220 or 440?
This would give the the base speed and also allow variable speed.
BTW I would look for one with better than the beat-up ways shown on that one.
What will be the freight??
Old 01-10-2007, 03:00 AM
gridley51: Yes, I could find one there. But there are a bigger selection of Bridgeports on ebay.com. And very often, the sellers att ebay.co.uk don`t send to Norway. Most often they just send to UK or it`s just lokaly pickup option.
Al_The_Man: I have 230v 3-phase available in my shop. The problem is the frequens on the machine (60Hz), and the frequens in my shop (50Hz).
The machine was just an exampel. You`re right, it didn`t look so good. The freight from USA to Norway is very cheap. For a package on 1500kg, I pay $500 (shipped with boat, 4 weeks deliveri).
Old 01-10-2007, 09:03 AM
Al_The_Man's Avatar
Then in that case, I would go with a VFD, If it is a 4 pole motor, you can run from 0 to 120hz, 2 pole 0 to 60hz, by the time you change out the motor and modify mounting etc, it would probabally be the same cost, VFD's are plentifull on ebay.
Old 01-10-2007, 02:21 PM
ivan sandford is on a distinguished road
bridgeport motor
hi if you visit http://www.assettrade.com/en/auctioncalendar.asp (you will need to register ) there is a current auction in the UK that has loads of Bridgeport mills and there is a list of approved transport company's.
as to the 50hrz-50hrz problem as far as i know you should be able to run a 50hrz 3 phase motor on 50hrz with no problem. (I have worked with American touring bands that had 60 hrz rigging motors we ran them on 50 hrz with no problems) good luck!
Ivan.
Old 01-10-2007, 04:25 PM
riverrat is on a distinguished road
Al I could be really wrong on this, tell me if I am please.
if you run a 60 hz. motor on 50 hz. , would'nt it just run a little
slower? isn't the voltage the primary concern?
an ac. motor is just chaseing the wave form, no?
Old 01-10-2007, 05:00 PM
Al_The_Man's Avatar
For best results you should actually reduce the voltage on lower frequency, The same voltage but lower frequency will produce slightly more torque due to increase in current but if loaded continuously without decreasing the voltage, lower Hz can cause overheating and premature failure of the motor.
A motor is an inductive device and is frequency dependant.
Very low power motors like turntables etc, you would only see a difference is speed but very little failure.
Old 01-10-2007, 05:10 PM
follow you clearly Al, on a bridgeport mill the guy should be fine.
right?
never seen a knee mill loaded continuously.
btw Al, you are a wealth of knowledge, thank you from everyone.
dino
Old 01-10-2007, 07:14 PM
D.D.Machine is on a distinguished road
I have had two BP mills that are marked on the front for 60 or 50 hZ
there not rare at all. just a little slower on 50 is all.
  #11   Ban this user!
Old 01-19-2007, 09:35 PM
AlanD is on a distinguished road
Motor Speed Controller serves Dual-Purpose
3 phase motor speed controller have become VERY affordable and with the correct choice of controller (and BP motor) will probably READILY accomodate the voltage and frequency issues that concern you - AND - give you a wider and more convenient fully adjustable spindle speed in the same small box. Furthermore, you buy a BJ with 3 phase motor (probably at lower cost than 1 phase).
I recommend you discuss the specifics with your local industrial electrician. The 50~60Hz compromise on power will probably be eliminated by the controller. For VERY heavy machining a fan can be added to ventilate/cool the motor.
Alternatively, in the modern world of global transport facilities, just get an freighting AGENT to quote you for arranging the shipping to Norway from UK or Europe (if the vendor is inexperienced or un-willing to help).
ac[QUOTE=Sperstad;240209]Hello
I`ve been planing to buy me a used Bridgeport machine from the states now. But since almost all Bridgeport machine only can handle 60Hz current, and not 50Hz, this may bee a problem. Here in Norway we have 230v and 50Hz.<snip>
  #12   Ban this user!
Old 01-21-2007, 04:39 PM
colin1544 is on a distinguished road
three phase on a 60 hz motor
hello there I had this problem in the UK and thought that when it tripped my first VFD controller there was a problem due to the motor being for the US market of 60HZ but if you get a VFD inverter with programmable frequency input setting you can overcome this because running at 50 HZ increases the amperage and with an unloaded spindle it will draw about 6.5 amps and probably trip your inverter after a short time but if you set it up for 60 HZ input it drops it down to about 3.8 Amps and gives plenty of loading for heavier cuts hope this helps Cheers Colin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
