Old 01-08-2007, 08:47 PM
IeatSteel is on a distinguished road
r2e3 with 4000 code boss8
ok to start iam not the cnc pro like most on here, so here goes...i have had my machine up and runnin for about 6 months, the machine has had few problems, but overall a good machine. i have let the machine sit for about 3 weeks and when i powered it up it was having a 2000 code set, so i did a search about it , and found that it may be a bad conn, on one of the boards. so i went and just pulled them out and put them back in just to make sure they were all plugged in good, i reset it and it did the same thing so i just wiggled them some more and the machine cleared the code and went into trying to home the machine ,(ok bad conn, but workin now)) then when i go to home the machine it had a error 4000 code about half way goin home...so i hit the rest button and the machine cleared the code , i enable the drives(which for a sec would not lock on) they start to sing , then i hit exe button and the 4000 code again. so was lost at this point. i hit the e stop then tried to home a few times, same thing ,after toggle between e-stop and enable drives the code would sometimes clear and say axis limit,which it does when homing i just have to jog the x over a lil and it would clear, but now the table will move x and y and the limit still there so i go to move the z axis and the error 4000 code came back...i then thought it was my z motor brushes worn so i then removed the brushes , they were worn some but not worn out, alot of carbon dust from the worn brushes , i took all of them out and blew some compressed air trying to remove most of the carbon dust, i then reinstalled the brushes, reset and tryed again, same 4000 code ...i then noted that when i hit the axis enable the z motor will pluse,i was going to remove the motor and clean it out a lil better, i tried to clean itone mor time on the machine on the machine again but left the encoder off and tried to enable the drives, the z motor would just spin until i e-stop, so i then thought the motor was good since it was moving,the motors have been replaced lookin at the date on them, i then searched the site agin and have not found what i need to solve my problems, i know you guys know these machines like the backs of your hands, so your help is greatly needed,i just need to know where and what to do next... thanks guys for any info, Brett
LOST , BUT LEARNING
Old 01-08-2007, 09:22 PM
Moderator
machintek is on a distinguished road
first question: is the Z belt on or off? this machine is notorious for jamming the quill up.
2nd question:Have you tried putting the encoder back on?
George
Old 01-08-2007, 10:06 PM
the z belt is on , and the encoder is on . the only time i could ever get the code to clear was to toggle between enable drives and e-stop kinda fast when the code was cleared(but said axis limit) i could jog x an y but when i moved the z it would reset the 4000 code..so thats what lead me to the z motor...all the drives are working i have not seen the fault light on them at all ...i could take the z motor an turn the motor and move the spindle down, with the e-stop on . then i would enable drives while the encoder was unpluged and the motor would just move the quill up. i have always hit e-stop before the spindle would hit the limit switch, i tired this a few times just to check th motor, does the encoder make it set the 4000 code ..also is there a trouble shooters gudie with the codes in it, i only have parts and program book... thanks again ....i also noted some oil on the board in the back...what do i do to clean these boards and connections..noticed the static warning didnt want to mess up my boards
Old 01-09-2007, 06:29 PM
Unhappy
ok ...today this is what i have done to the machine. i have check that all the drives move freely, i have unhooked the enconders and all the motors will just float ,they spin very slow but they turn, i removed the z encoder from the motor, and with the spindle down a lil i could turn the encoder jsome and the motor would run fine. so does that mean the motors are fine? they all move,
i have put a mirror in front of the drives so i could notice the leds while i engage teh drives, but i have not seen the leds on the drives come on . i hear the chokes engage and start to whine, but no leds , the leds on the emdc board are blinking right(maybe) , the frist two are blinking the second one is on and the last one is on , when i enable the drives the six led comes on , the first led that is blinking is a fast blink and the second one is blinkin slower. i have also tried to remove the 17 fault wire on all the drives, nothing i have jumped them to pin 20, nothing . then i measured the volts on the 17 (360/361), its right at 15v(14.7).so jumping it to pin 20 is not doing anything is it , pin 20 15v and wire 17 15v...or is this my problem...thanks again guys for you thoughts.. Brett
Old 03-19-2008, 01:06 PM
cmmachine is on a distinguished road
Brett,
Have you solved this problem with your machine? I am currently in the same boat but I can only jog the X axis and when I try Y the machine locks up.
Mike / cmmachine
Old 06-01-2008, 07:40 AM
MrBoss8 is on a distinguished road
The front panel 4000 code = "Drive Fault" check all fuses, and verify DC power to each drive.
(2000 = "Internal Communications Error")
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
