Old 12-29-2006, 03:19 PM
vettespeed is on a distinguished road
Bridgeport Torq Cut 22 - Spindle/encoder problems, bad?
I have a 1995 Bridgeport Torq Cut 22 that I have just got up and running in my garage. I am having problems with an alarm stating "spindle not up to speed in time". When I watch the actual RPM I notice that when I start with a spindle speed too fast the spindle speed stated on the screen radically fluctuates all over the place and at times will actually say 0 (zero) when the spindle is obviously going many thousand RPM. A couple seconds after I see the spindle speed on the screed fluctuating and obviously not accurate I get the alarm. Strangely enough if I start the spindle at a very slow RPM, there seems to be no problem. Then as I slowly increase the spindle speed it reaches an RPM where you start to see the RPM fluctuate, the faster the spindle goes the worse the error is. If I gradually ramp up the RPM I can start to see it fluctuate and I just simply wait a little while at that RPM then it evens out, then I can go a little faster until I see it again fluctuate then I again wait for it to level out, etc, etc. It is as if it needs to warm up. Admittedly the garage is quite cold, 40 degrees or so when I start up. Is this an encoder problem. Will these machines/encoders work in a cold climate. Any thoughts would greatly appreciated. Also I'm assuming what measures the actual RPM of the spindle is indeed the encoder??? The little component that has a little gilmer type belt that comes off of the spindle??? Thanks, Mike. vettespeed68@hotmail.com
OH CRAP,
And to add to my problems, I just called Bridgeport/Hardinge and the encoder is obsolete and no longer made by the manufacturer! Anyone have any ideas as to where to get one or get mine repaired if this is indeed the problem? Thanks again, Mike.
Old 12-30-2006, 12:47 PM
Kevin Taylor is on a distinguished road
Vettespeed You might have a lose conection if the problem is interminte I would think warming up the shop would help My BTC will drop tools if it's to cold check Ebay BPTtools I think is the screan name of a guy on the east coast that bought a lot of the inventory form BBT's sale he might have what you need The spindle speed is measured with a prox switch reading the teathe on a gear in my BTC Good luck Kevin
Old 12-30-2006, 01:19 PM
Well i did pull the plug on the encoder and make sure there was a clean connection, it looked fine. It is not an intermittent problem, it always happens when it's cold and seems to be getting worse, might just be that it's colder now. Usually it takes a good 20+ minutes of slowly ramping up spindle speed to get it to work properly so I just went out in the garage and stuck a blow dryer down through the top of the sheet metal toward the encoder for about 2 minutes before I fired up the machine and sure enough I was able to to right to fast spindle speeds (6000 RPM) without any problems, usually I can only get to about 1700 RPM before the spindle speed shown on the screen starts wigging out and I get an alarm. Hopefully the problem does not get any worse because if all I need to do is warm it up with a blow dryer for a couple of minutes I guess I can deal with that. I'll look for that guy on eBay. Kevin, you say your BTC dropped tools, what's a BTC? Also who or what is BBT? Thanks, Mike.
ANYONE KNOW WHERE I MIGHT BE ABLE TO GET THIS ENCODER REBUILT? IT'S A HEIDENHAIN ENCODER AND THE BRIDGEPORT PART NUMBER IS 11597392.
Old 12-30-2006, 01:40 PM
Al_The_Man's Avatar
Providing it is a Square wave output and not a Heidenhain sinewave type, you should be able to sub any make of encoder, as long as you have the right resolution, the part number will tell you the resolution and if you list it, I could tell you what the output type it is.
Old 12-30-2006, 01:44 PM
11597392 is the Bridgeport part number, did you mean the Heidenhain part number? If so that is not shown in the Installation and Maintenance. I suppose it might be on the encoder, I would have to remove the sheet metal again and find it. Thanks, Mike.
Old 12-30-2006, 01:54 PM
NC Cams is on a distinguished road
In light of the "thermal problem", I'd almost expect that there is an air gap issue that extreme cold temp is creating havoc with. Not surprising if it is die cast aluminum.
However, I'd try contacting Heidenhain directly. Don't be surprised, however, if they need to send it back to Germany for repairs. There are also outfits, however, that specialize in servicing encoders on an aftermarket basis.
I found several via an Internet search when looking for info on a Tamagawa encoder that was on my N/C lathes. Googled "tamagawa encoder" and went hunting from there.
NOTE: some of the Heidenhain encoders that BPT used were semi-custom's that were made especially for BPT. Although it might not be serviceable "as is", something should be adaptable. Koyo makes quite a few variants that might work.
I would think, however, that the encoder is a typical quadrature deal and, asside for counts per rev, should be relatively 'standard'. 1024 counts/revs is quite common with a single pulse per rev indexing pulse. Surely, Heidenhain might have something that could/would replace it.
Last but not least, have you tried contacting EMI???
Old 12-30-2006, 01:57 PM
I'll do some searching and see if anyone can rebuild this one or have something to replace it. I tried EMI yesterday but I think they're closed throught the holidays, I'll try next week. Thanks, Mike.
Old 12-30-2006, 02:03 PM
Al_The_Man's Avatar
Originally Posted by vettespeed View Post
11597392 is the Bridgeport part number, did you mean the Heidenhain part number?.
The heidenhain number is on the encoder, considering the age and the mechanical wear, apart from the electronic problems, I would consider replacing rather than repair, Heidenhain encoders are typically in excess of $1000.00
One company that sell the heidenhain direct equivalent that is much cheaper is Hengstler.
Old 01-02-2007, 04:19 PM
Looks like both EMI and BPTparts.com have an encoder for about $600.00 and EMI also gave me a line on a place that could possibly repair the old one for half the cost of a new one. That company is AMS (Accurate Measurement Systems), 314-890-0002. I attatched a photo of the tag off of the encoder and also a picture of the encoder. Thanks, Mike.
Old 09-11-2008, 05:07 PM
MahdiEynian is on a distinguished road
I saw a ROD 420 encoder in Heidenhain catalog. I wonder if that one is different from yours.
  #11   Ban this user!
Old 09-11-2008, 06:54 PM
mactec54 is on a distinguished road
Hi vettespeed
Your encoder is a 500 line you can use a 1024 as well but will have to change some settings in the control in your photos it looks very dirty/wet up around the encoder I think a very good clean up is needed we do have some of these encoders but are not selling them as we still have 8 of these machines that are used everyday I think that your encoder has got oil or some coolant in it by the mess that is a round it
Mactec54
  #12   Ban this user!
Old 07-28-2011, 04:16 AM
rozer2012 is on a distinguished road
sir nice suggestions
Floor levelling
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
