Old 12-26-2006, 04:39 PM
boringmill is on a distinguished road
Ajax or Centroid users
Hi,I would like to know if anybody has tried an ajax/Centroid retro on their Bridgeport mill.I have two that are canidates for retrofits and would like opinions.Thanks
Old 12-26-2006, 05:09 PM
colin1544 is on a distinguished road
bridgeport AJAX retrofit
Hello Yes I have done a retrofit on a series 1 bridgeport CNC very straightforward as long as you have some electrical knowledge the mechanical side is dead easy but check your parts carefully and plan your procedure as although the motors are the same frame (42 Size motors) the keyways are different and you also need a 1/8" packing plate under the Z axis motor as there is a Location boss on the face of the motor which is larger than the bore of the hole of the hole on the Z Axis cast motor bracket also consider the options you will need and order it altogether the spindle speed option is very useful if you are going to use an inverter instead of the air motor driven electro - mechanical origonal system, check also what type of command inputs you are going to use be it a Keyboard or the manual keypad plus the key board these options are all very useful but add up to a fair old price and maybe other systems are cheaper with all the options being included typical extra is engraving you would think that with normal keyboard operation this would be standard but this a 665$ extra all in all though I have been pleased with my retrofit although I would like some of the extras I cant afford them as yet, The programming is relatively easy to learn so take your pick but get quotes from other suppliers then make your choice Cheers Colin.
Old 12-26-2006, 07:10 PM
DRD DRD is offline
DRD is on a distinguished road
I did a AJAX, 4 axis conversion, on my 9X50 Lagun mill.
If you have electrical knowledge, it's a slam dunk.
Dollar for dollar, the controls can't be touched. I use my system to digitize cylinder head ports, and then machine, stock ports to what I digitzed.
The control is laid out very nice, and work excellent, very smooth movements.
If your in a industrial enviorment, the controls are great.
If it's to hobby around, and you have alot of time to spend, there are alot of pc based controls that will do the job, but plan on spending alot of time to get them to work.
Like they say, you get what you pay for.
Good luck!
Old 12-27-2006, 05:03 PM
Newby2 is on a distinguished road
I will be purchasing an Ajax system for my BPT R2E3 in the very near future. In researching this, I found out that I can use my existing SEM 28 in lb servos but will have to upgrade the encoders (included) Though to some it may be a bit pricy at $7K, I believe I can recover that amount in a short period. I have the need for a more updated control, more than a 2 line display. The price I was quoted includes a more modern MPG.
I like the idea of having a dedicated control. PC based, particularly windows, has to much garbage running in the background for a CNC machine.
Steve
Old 01-01-2007, 01:24 AM
wddanie is on a distinguished road
What kind of accuracy do you see on your Ajax/Lagun mill? Was it a cnc Lagun before the Ajax conversion?
Thanks,
Doug
Old 01-06-2007, 02:49 PM
NC Cams is on a distinguished road
Look for some posts by a member called "SIZZLEMAN" or something close to that. He had some VERY unpleasant experiences with Ajax/Centroid.
There were some other horror stories with regard to promises made and not kept. Ditto that with regard to less than exemplary service support practices.
There are always two sides to a story but I'm still waiting for a call back from them concerning a lathe retrofit inquiry - and that was placed LAST SUMMER!!!.
Old 01-06-2007, 07:08 PM
I found a co. that is certified thru Centroid in my area that seems to be able to give a better deal on the price.Maybe Centroid dont want to deal with the one man shop types?Thanks for all the input.
Old 01-07-2007, 10:26 AM
DRD DRD is offline
Thanks,
Doug[/QUOTE]
Doug, the controls will hold .0001 easy. My machine, will hold .0005, the machine it pretty rigid mechanically.
The accuracy de pends on how tight the mechanical parts are.
Ajax was allways there to support me.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
