  #25   Ban this user!
Old 12-17-2006, 03:26 PM
philbur is on a distinguished road
The taper on the end of the tool shank is something I suggested earlier. Thoses arms still look like a weakness in the design to me though. Take a look at a few commercial tool changers for ideas. Do any use a similar arm concept. If not why not.
Having design tools is one thing, what is much more important is following the correct steps in the design process. For example, what are the primary functions of the arms, how well do they fulfil those functions, what alternative might fulfil those functions better. It is a much better approach to look for why a particular concept will not work rather than why it will.
Regards
Phil
Originally Posted by daedalus View Post
I have yet to actually see a tormach tooling system up close, but could you put a very small chamfer on the end of the parallel shank, and then use the compliance in the arms to locate the tool correctly during pickup? This would relax the positioning constraint to having to get the top of the taper section under the parallel bore.
On the prototyping front, i have cosmos here, so will be doing a fair bit of analysis before i build anything. Im still only doing background research at the moment.
  #26   Ban this user!
Old 12-17-2006, 04:17 PM
Willbird is on a distinguished road
The FADAL tool changer is pretty simple, it uses a wheel to hold the tools, moves the whole wheel TO the spindle to grab a tool, moves the spindle UP to get it off the tool, rotates in the necxt tool, moves the spindle down to grab the tool, moves the whole wheel away.
You need more Z travel for this but there are only two motions needed for the tool changer, one rotary to postion the wheel, one linear to move the whole wheel in under the spindle. It avoids the complexity of needing to rotate a pot 90 degrees to put it in the same place as the toolchange arm like some systems do...or move a pot to standby position like some others do....there are no pots, just the round wheel with pockets cut and simple methods to hold the V flange in place
Another nice thing about their system is you can just type SETT0 <thats a zero) and resequance the whole wheel so that you can leave tools for a job setup in there, later to go back just spin it around and SETT0 again and reload the offsets, good to go :-).
Bill
  #27   Ban this user!
Old 01-05-2007, 06:24 AM
krymis is on a distinguished road
guys for the past year i have been working on something. I was thinking of building an arm that houses a 12 pot rotating carassel. That carassel is moved into position by an electric linear actuator with stop switch and positioned stop blocks for the alignment. The arm is mounted to the lag bolt holes and secured. there would be a servo driving the carassel with an encoder. Now i was using the encoder and a macro to state the proper alignment of the tool pot. Add to that a point sensor such as that discussed and a macro and that will tell if there is a tool in place. No sensing the tool throw a program stop and wait for a continue action. Now let me mind you i have no engineering degree nore have i been at this very long so my idea may just be a pie in the sky but it started out and has slowly started to take shape. A lot of it comes from joe's plans too. I use his drawbar and i can not say enough about it. I am also using bobcadv21 and mach 3 software and an industrial hobbies mill with the tormach qcts and joe vicar's drawbar for this.
Old 01-05-2007, 06:31 AM
Gold Member
InspirationTool is on a distinguished road
You might also look at the kwik switch taper. There are holders available for R8 spindles, and some bridgeport spindles are kwik switch instead of R8.
I have links to the all the manual quick change systems I know about here:
http://www.jeffalbro.net/cnc/quick-change/
-Jeff
  #29   Ban this user!
Old 01-05-2007, 03:25 PM
Tormach is on a distinguished road
TTS for Automatic Tool Changer
There are several people that have spoken to us about developing an automatic tool changer using TTS. In most cases they are looking for some simple geometry modifications to facilitate their work, mainly a taper to the end and a slot for a tool holder clip.
In order to facilitate their development efforts we have designed a TTS-ATC special. I have tried to attach a JPG with details. This tool will be available sometime in February. If anyone gets a tool changer to the point of an effective commercial product we will support them by making these changes to the entire line of TTS. It's also relatively easy to make these changes to existing tools if you use carbide tooling.
Greg Jackson
Tormach
  #30   Ban this user!
Old 01-05-2007, 09:45 PM
NinerSevenTango is on a distinguished road
I like that groove, Greg. With that, something reasonably stout could be designed.
Might have to perforate the column in a few spots, though!
--97T--
AKA John from Induction Svcs
  #31   Ban this user!
Old 03-01-2007, 06:32 AM
digits is on a distinguished road
Greg Jackson
Tormach
Are the ATC friendly versions of the toolholders likely to be available to the public for those of us who'd like to try to build DIY tool-changers?
Looking at the diagram you posted, are the dimensions of the taper at all critical, or is it just there to allow for some misalignment between spindle and tool-holder?
  #32   Ban this user!
Old 03-01-2007, 09:09 PM
ATC experimental tool holders
The tool holders are in stock. They're not on the web site, but you can call or email to order them. We only made 3/8" for the test:
PN 30587 "TTS - 3/8" Special Test holder for Automatic Tool Changer Development"
The price is $20.75, the same price as the regular holders. There is nothing special about the entrance taper. The best size and angle of that taper will probably be established by some experimentation with an ATC. I would expect different ATC designs to work a bit differently.
Greg
  #33   Ban this user!
Old 03-02-2007, 05:08 AM
Thanks for the reply - much appreciated
  #34   Ban this user!
Old 03-05-2007, 08:44 PM
Zumba is on a distinguished road
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
