Old 12-10-2006, 12:58 AM
raymond1 is on a distinguished road
Constant Surface Speed
Need Help On Calculating The Constant Surface Speed On The Lathe How Do You Know What To Put In For A Part That Has A Big Diameter Of Say 20inches And A Small Diameter Of 12inches. Its Sst.
Old 12-10-2006, 02:59 PM
Willbird is on a distinguished road
I'm not sure what your asking exactly ??
Typically with constant sfm you clamp the max spindle rpm so it does not run to the max the spindle can run when it faces to center, it is important to consider the centrifugal force on your chuck jaws when using constant sfm. If you wing the spindle too high of an rpm the chuck may explode, the part can come out, small animals may die, you may die. Often a clamp on maximum spindle rpm (by G or M code) is a very important part of a cnc lathe program often overlooked.
The cheap and dirty formula I use is
(SFM * 4)/dia of part = rpm
it is not exact, but it IS easy to remember...and it errors to the conservative side on the rpm.
Old 01-07-2007, 01:19 AM
HOW DO YOU FIND THE (SFM) IS THERE SOME KIND OF CHART AND ALSO CAN YOU DISCRIBE ON EXAMPLE. LIKE SAY I AM MACHINING A ALUMINIUM PART THAT IS 14 INCHES IN DIAMETER HOW WOULD i FIND THE RPM FOR THIS PART
Old 01-07-2007, 02:04 AM
Chip Maker
ricotututi is on a distinguished road
SFM is a myth you get this from the tool manufacturer, or there is something standard with high speed tools or cardide, and then it depends what type of material your cutting, and if you are using coated tools then the SFM might double or triple.
From what I remember usualy for
High Speed tools is about 50-100 for steel
Carbide about 200-350 for steel
for alum it probably can be twice than for steel
for Stainless Steel its probably 25-50% lees
and example would be
lets say you are machining
a 1.0 diameter aluminum bar stock
your smaller machining diameter is .500
Then you calculate 350(SFM) x 4=1400 / .500(smaller diameter)=2800(RPM)
This means that when your machining your .500 diameter the lathe will running at 2800RPM .
then you have to input this information in the program
What I use is something like this
G50 S2800 (this is the maximum RPM the machine will run)
M3 S1000 (this is the RPM at which I will start the spindle before start cutting)
G96 S350 (This tells the machine what is the SFM, so the machine will calculate and change RPM accoding to the Diameter)
hopefully this makes sense.
Old 01-07-2007, 03:32 AM
Thanks For The Quick Reply .by Any Chance Do You Know Where There Some Kind Of Chart Where I Can See On All The Material And What To Punch In For The (sfm). Also Do You Know If They Sell Some Kind Of Calculator Not A Software. That Will Figure All That Stuff Out For You.
Old 01-07-2007, 05:05 AM
philbur is on a distinguished road
Try:
http://www.niagaracutter.com/techinf...eed/chart1.gif
Or google "speeds and feeds"+chart.
Regards
Phil
Old 01-07-2007, 10:50 AM
Machinerys Handbook has all that type of information; no calculations are needed. For example if the cutting speed for is 450 fpm your program needs the command G96 S450 to start the CSS. Depending on the size of the material you will have a G50 Sssss spindle clamp command; if your work is large you might want to clamp the spindle to a low or medium rpm and if your work is small you might use a faster rpm. The spindle clamp has nothing to do with the required sfm it is for safety as you do not want the chuck to loose grip at very high rpm on a large part.
Incidentally the chart philbur linked is for milling cutters. It is not always valid to use the same sfm for a lathe tool because the cutting conditions are very different. Lathe tools are always buried deep in the cut and may overheat if run at the same sfm as a mill which often spends 50% of its time away from the material and freely exposed to cooling air or coolant.
Old 01-07-2007, 12:16 PM
easiest to remember is SFM x 4 / DIA = RPM so for a 1" cutter running 150sfm
100 x 4 / 1 = 400 rpm
To never melt a cutter in any unknown steel that is not harder than 4140ht I simply use 50sfm for HSS and 150 for carbide, this is for milling machines that are not super rigid, this is quite conservative. but often the cut takes less time than looking up the EXACT speed/feed for A2 steel, or D2, or 4140ht
Bill
Old 01-07-2007, 08:33 PM
Newby2 is on a distinguished road
For those interested, I run stainless at 200fpm roughing, 350fpm finishing. Depending on the steel being turned, I run 12L14 at 750fpm@.09DOC for roughing, and 1100fpm finishing@.015 DOC. 8620 will run a little less, but not much, with the DOC remaining the same. These are using flood coolant.
The Seco/Carboloy recommended feeds and speeds are higher than that but the tool life is greatly less. I use TIcn coated inserts but find the TINal inserts last longer. I can run 4 hours (half a day) on one corner, index the insert after lunch, and run the rest of the day.
Another thing interesting is that the insert manufacturers are placing the various materials in catagories based on the materials machinability and placing this information on the label of the insert container.
The formula I use for SFPM is simple, Pi * DIA/12 * RPM. (Pi =3.1416)
Steve
Old 01-07-2007, 10:17 PM
DocHod is on a distinguished road
To let you know not all machines controll the max. R.P.M. by using G50 one of our controllers uses a G92 for max. R.P.M.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
