Old 11-24-2006, 10:54 AM
Hood is on a distinguished road
BOSS 6 T2 transformer
Does anyone know the VoltAmps rating of the T2 transformer from a BOSS 6. Thanks
Hood
Old 11-25-2006, 09:17 AM
Moderator
machintek is on a distinguished road
Hello Hood,
Look on top of the transformer. I remember a plate being attached there with some facts about the transformer on it. Other wise I would look in the maintenance manual. Some have a list of parts with some generic data. I will see what I can look up as well.
George
Old 11-25-2006, 10:08 AM
Thanks George
There is nothing on the transformer apart from terminal numbers and also a number (ES922), also my manual just tells me its T2 and no other infomation apart from what voltages to expect. I removed this transformer from my mill when I retrofitted it and I am now embarking on doing a retrofit of a lathe and was kind of hoping that this transformer would be sufficient for it. The voltage is perfect but I am hoping the KVA will suffice.
I really appreciate you taking the time to find the info.
Hood
Old 11-26-2006, 05:49 AM
Does anyone have a wiring Diagram for the T2 transformer, My manual is a bad copy and I cant make out the numbers. I am thinking I am going to have to wire for 460V as I am geting 63V out and I need less than that, I am presuming its wired for 420 at the moment.
Would really appreciate if you could post a scan or send to hood@rdengineering.wanadoo.co.uk
Hood
Old 11-26-2006, 09:04 AM
Eric is on a distinguished road
My BOSS 5 says the total electrical power is 3KW. Then the spindle motor says 1.5KW. So this could mean the T2 transformer is rated for 1.5KW.
Old 11-26-2006, 10:06 AM
Eric
Thanks for the reply, however I think really that the transformer may be well above what is needed for the bridgeport, its huge, much larger than I would expect for 1500W. It weighs about 45Kg (100lbs), I am a total novice however so may be totally wrong, usually am
Do you have the wiring diagram for the T2 transformer, I got the manual with my mill in the form of a pdf from machinemanuals.net but the scan of drawing (1040222 sheet 2 of 7) is very poor and I cant make out the terminals for wiring 460V.
I would really appreciate if you could scan it if you do indeed have it.
Hood
Old 11-27-2006, 06:51 AM
jderou is on a distinguished road
Will a .tif work?
If you try to make everything idiot proof, someone will just breed a better idiot!
Old 11-27-2006, 02:01 PM
I just went out to the BOSS 5 and looked at the name plate on the transformer. Here is what I found.
3 Phase, 60 Hz
Pri - 230/460V Delta 10/5A
Sec - 60/70/80V 15A/Phase
Insulation Class B, 80*C rise
Spec # 021374
Design # 16970001
For 230V input:
Primary:
X1, Y1, Z1
Jumper:
X1-X3, Y1-Y3, Z1-Z3
X2-X4, Y2-Y4, Z2-Z4
X3-Z4, Y3-X4, Z3-Y4
For 460V input:
Primary:
X1, Y1, Z1
Jumper:
X2-X3, Y2-Y3, Z2-Z3
X1-Z4, Y1-X4, Z1-Y4
While looking at the transformer, the windings from left to right are: Z, Y, X
The secondary taps are:
5 = 0V (common)
6 = 60V
7 = 70V
10 = 80V
Old 11-27-2006, 03:40 PM
jderou
Excellent, just what I am looking for, thanks, much appreciated.
Eric
Thanks for the info, appreciate the trouble you have gone to and although its a bit lighter than I thought and hoped for it should still work fine as the secondary is giving 15Amps per phase.
Thanks guys.
Hood
Old 11-28-2006, 04:52 PM
Just an update, I wired the transformer for 460V as per the drawing and I got 55V AC , rectified it and got 75VDC added capacitors and it is spot on 77V DC which is perfect.
Thanks jderou and Eric, your help is much appreciated.
Hood
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
