Old 11-23-2006, 12:05 PM
s1j1m10 is on a distinguished road
Question R2E3 Boss8 Drive Fault?
My old BP is coming up with Error4000 after about 1 hours running. (Manual says that this is error 4 in group 1 ie a Drive Fault). If I leave it for some time I can run again for another hour or so??? I have checked on the NC400 drives and sure enough one of them showed a drive fault light on the side so I switched the boards around to see if the fault followed the board but it is not the NC board as a different board lit up later??? Has anyone had a similar problem or can they suggest where I should start looking next?
This m/c now works fine with the door open and a big fan cooling the nc400 drives. The fuses are fine but I cannot find out why 2 of the fans are Kaput yet!!!
SteveSteve
Old 11-23-2006, 08:40 PM
scotts-repair is on a distinguished road
R2E3 Drive Fault
Mine just started doing the same thing. Did you solve your problem?
Scott
Old 11-24-2006, 02:14 PM
Unhappy
Problem not solved yet. Have read through the thread on Boss8 error 4000 but not tried to check any voltages. Have switched boards a number of times now but problem moves between NC boards and position randomly so must be on underlying circuits. Am going to try a big fan to try to keep the drives cooler as this oly occurs when the machine has been running for some time. If this doesn't work them I am going to start to check connections. Let me know if you find out anything with yours.
SteveSteve
Old 11-24-2006, 08:59 PM
Newby2 is on a distinguished road
I have this happen (error 4000) a couple of times so far and just tap the E stop, rehome the machine, and continue on
Steve
Old 11-24-2006, 11:50 PM
Moderator
machintek is on a distinguished road
It could be in the motors as they are DC motors and have brushes which wear.
George
Old 11-26-2006, 03:56 PM
I just solved a problem on my R2E3 Boss8 I from a thread that machintek wrote about a year ago. George suggested giving the IC's a crackle test and cleaning the connectors on all the boards. I just did this about 10 minutes ago and lo and behold, the machine is back up and running! Thanks George!
Steve
Old 11-28-2006, 12:06 PM
Have tried tapping the E stop but this didn't work. Will have a look at the motor brushes next and try cleaning up a few things.
SteveSteve
Old 11-30-2006, 11:18 AM
Looks like I may have solved this problem. We noticed that it always happened after running for a couple of Hours and can now see that the 2 fans on top of the NC400 boards are not running so we think that it is just an overheating problem.
SteveSteve
Old 12-01-2006, 12:35 PM
OK I have found the problem --but not the solution. The 2 fans on top of the nc400 drive boards are not working. This means that the drives are probably overheating and there must be a safety cut out son after a couple of hours I get the drive error. Now it seems to be strange to me that both fans are Kaput so I am not looking throught the maintainance manual for the fuse numbers etc. In the mean time I have the door open and a big fan blowing lots of air over the drives which seems to work but looks bad!!!
SteveSteve
Old 12-01-2006, 06:09 PM
According to the fuse listing I have, there are 2 fuses located on the axis drive mounting board. They are #25 and #26, MDL,1A,250V style. I believe you may have to pull the NC 400 drives to get at them easily. There are 4 fans located in the drive enclouser that I have and two of them are controlled by fuse #5.
Steve
  #11   Ban this user!
Old 12-01-2006, 07:40 PM
I would like to post a new thread here but I can only enter a subject line and cannot enter a sublect matter...any leads?
Steve
  #12   Ban this user!
Old 12-02-2006, 03:01 AM
Saga continues
Tested these fuses and all OK. The 2 fans on the top of the nc boards do not work but the 2 fans at 90 degrees (facing the door) do work!!!
To post a new thread just go to the opening page of the Forum (in this case Bridgeport & Hardinge Mills) and there is a button at the top left.
Anybody know if T3 transformer powers anything else? These fans seem to be wired directly into T3.
OK now after checking there appears to be a relay between fuse 5 and the Fans which seems to be called CR1 in the diagram!! This does not work according to my meter so I am now getting a "KRP11DG24" Potters & Brumfield replacement unit to try. Luckily leaving the door open with a big fan blowing on the drives still seems to work just fine!! Maybe I could put the mill in a wind tunnel!!!
SteveSteve
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
