for what reason?
the boss 6 motors are steppers, each step moves .0005".
Matt
does anyone know of any success stories of mounting and encoders on the existing boss six motors?
for what reason?
Matt
to take full advantage of the new gecko drive G100 you need to install encoders on your motors. This system will sense in impending stall and coordinate the remaining two motors to slow down and keep your position.
did your machine have Trav-a-dial on there? Take those things off and use an encoder on the ballscrew. I haven't really been keeping up with the GRex, does the unstallable stepper mode currently work?
I tried this back in 2003 and yes the travel dial is where I mounted the encoder. If you take the back cover plate off the motor you will see you can not attach it there very easy.
The main advantage would have been speed ( Same resolution.). I have broke many tools but never stalled the original steppers to the point of missing steps. I never got it to work good with the original drives. It was going to take a redesign of the stepper drive to accept the PWM drive signals from the MaxNC CL software.
I started using Mach software with the original drives and liked it so much I did not pursue the MaxNC CL anymore.
It would be nice to see a stepper/encoder drive that would accept step/direction signals and interface with standard steppers. This must not be an easy task. Of course digital AC drives with matching motors, Yaskawa of course, would do the trick!
Darek
It's not really that easy to use an encoder with a stepper, since your positioning authority is probably not as fine as the encoder resolution. It's analogous to having a servo motor and a linear scale on the same machine -- you have to use advanced techniques to make it improve things any.
Take a look at pico-systems.com. Jon Elson's Universal Stepper controller will take encoder input and drive the factory boss steppers. Requires the use of EMC at this point though...
