I *think* the reason they are advising against the autotransformer is because it provides no isolation which could cause a lot of problems if it were to fail. But, if you are using this just to step down between your supply and the existing bridgeport transformer you might be ok as the existing bridgeport transformer will provide the necessary isolation.
I'm not entirely sure on this so you might want to double check with someone else.
Certainly if you were intending to replace the existing bridgeport transformer with a new one I wouldnt use an autotransformer.
LinkBack URL
About LinkBacks
