Old 10-29-2006, 09:20 AM
tomindallas is on a distinguished road
Cannot dial in a Series II - any ideas?
Info: Series II with ballscrews, DC Servos and Gecko 320's.
I spent the entire day yesterday adjusting the steps per unit in Mach 3 mill. It's consistently off in the Y as seen in the pics. The aluminum part was cut before the additional adjustments, and the wood test was just cut this morning. It just seems off in the Y by 10 thou or so during the same run. Backlash was measured at .002".
The drives are not faulting and I performed the back and forth 4" movement test twice yesterday during the fine-tuning process with perfect results. I use a 4" gage block and it moves 4.000" each way. The part looks perfect on the tool path window in Mach.
This is my first part on a newly completed retrofit, so I'm very happy overall but getting frustrated since I can't get this problem figured out.
Any advice is appreciated!
Tom in Dallas
Name:	mill work 5 sm.jpg‎
Old 10-29-2006, 10:01 AM
keebler303 is on a distinguished road
When exactly does it get off target? Is the entire part cut with one program? If it moves 4.000 when you tell it to then your steps/in are right on. If the backlash is only .002 the only way I could see it being off is if you were losing steps from mach or your encoders were doing something funny.
What kind of computer are you running it on? You also might want to manully go through part of the g code to make sure the problem is not there even if it doesn't show up in mach. You could also make another program and see what happens with a new program.
good luck
Matt
Old 10-29-2006, 10:20 AM
Hi Matt -
Yes, one program. Currently it's drilling, then inside circle then outside circle. I just turned on backlash compensation in Mach and that was a mistake with the outside circle now hitting the holes on the far side of the part.
I'll change the code and cut both circles then come in and drill and see if the holes move toward the front of the machine as it should if it's losing counts or the steps are wrong (right?). If the holes are still in the wrong place then I already wish to claim G-code newbie rights for a hole location mistake.
Argh :-)
Tom in Dallas
Old 10-29-2006, 12:08 PM
For posterity:
Found the Y Gecko was jumping the motor around a little but was unable to get it to work perfectly by adjusting the pots - even min gain had it hopping around. Swapped it out with my A axis drive and it's fine now - I'll recut the part and post later today. I may have noise on the lines and one Gecko is unhappy about that more than the other - I'll learn how to use an o-scope and check this all out before I declare a bad drive in public.
Tom in Dallas
p.s. Had to run the program without the head running so I could hear the motor jumping - otherwise I never would have found it...
Old 10-29-2006, 01:53 PM
Ahhh, much better with a stable Y motor..
Name:	mill work 007 sm.jpg‎
Old 10-29-2006, 04:29 PM
NC Cams is on a distinguished road
Cutting a perfectly round circle is one of the hardest things for a stepper or servo to do because of the instantaneous and diverging changes in axis motion velocity that are going on.
You might find some interesting insight here:
http://www.cnczone.com/forums/showth...t=18178&page=9 (lots of detail here)
http://www.thewarfields.com/MT/CCBacklash1.htm
http://www.thewarfields.com/MT/CCBacklash2.htm
http://www.cnczone.com/forums/showthread.php?t=25181
http://www.cnczone.com/forums/showth...078#post202078 (especially post #41)
And, yes, it does help if motors are behaving properly.
Old 01-01-2007, 03:51 AM
wddanie is on a distinguished road
Tom, what accruacy do you get from this BP retrofit? Did you consider using the Pico Systems bds and emc?
Thanks,
Doug Danielson
Old 01-01-2007, 10:29 AM
DennisCNC's Avatar
DennisCNC is on a distinguished road
What kind of wires do you have from encoders to drives?
I have a setup were a encoder is near 3 VFD's and using twisted pair wires for the A B signals with A and ground twisted and B and ground twisted, get a nice clean signal from the encoder.
Dennis
Old 01-01-2007, 10:39 AM
Hi Doug - I'm limited by my physical backlash on the machine. I've not yet deemed the time to reduce the backlash per NC Cams links of high importance as the parts I put out all fit together fine. I'm not making aerospace parts here yet :-)
I was a Mach/Gecko guy from the beginning due to the huge user-support available.
Old 01-01-2007, 10:44 AM
Re: wires from encoders to drives. I bought the wires from US Digital to go with the encoders. The jumpy drive works fine on the A axis but I did reroute all my encoder wires and drive power wires to be separate as much as possible. Since the drive swap it's been a happy machine.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
