Old 10-27-2006, 04:46 PM
jkujawa is on a distinguished road
Your opinin please - evaluating a used Bridgeport to purchase
Hello,
I am looking at a used Bridgeport machine for my shop. We do light prototyping, mostly in aluminum, and though I have used a mill it has been some years so I am definitely a novice.
The machine I am currently looking at is priced around $4k, and has power knee and x, Sony DRO, pneumatic drawbar, Bijur oiler, and comes with collets and a vice. It has been in service in a place that does repairs on airplane components (they are FAA certified). The shop is very clean, large, and well equipped. In general all their equipment is current and very clean. This particular machine is being sold because they don't have the work to keep it busy and they are consolidating space. He admitted that this is the least 'tight' of the machines, but it only recently came out of service.
The owner of the shop seemed knowledgeable and honest. He told me what he knew about the machine, and what he didn't. He had no problems with me talking to the machinists about it. I am going back tomorrow or monday to fire it up and check the runout (I knew in advance I couldn't run it today because there was no power where it is. One of his crew offered to shuffle the machines to position it to run, but I didn't want to disrupt the productivity as my visit was unscheduled).
I have two questions:
1) The flaking on the Y ways is just barely visible, but the travel is smooth and consistent. In the last 3 photos below you can just barely see the pattern (it is a little more evident in person). What do you think about the wear? I am, as I said, completely inexperienced in this field.
2) The unit overall seems to be in good condition, and I think it will easily meet my needs (I'd like to be able to machine parts, mostly aluminum, with .001-.003 accuracy). What do you think a machine like this is worth?
Thanks very much!
They are replacing the switch. The part is actually in the photo, in that brown box.
A few shots of the ways - the brown stuff is NOT rust. It is kind of a waxy oil film.
Old 10-29-2006, 06:58 AM
snakebit95 is on a distinguished road
Well, the first thing I noticed when I looked at the photos is that the head is a different color than the base; which indicates it was replaced at some time. You might ask the question. I would also run the head through various speeds, listening for noises. Perhaps start in low-gear and step through a couple speeds, and then run a few speeds in high-gear.
Your photos of the ways indicate some significant wear. In my opinion, $4K is a bit high. But then again, most of the machines I see in good shape that sell for $2.5K-$3.5K do not include digital readout or power drawbar; so those items do add-up.
You may want to check the backlash in each axis to get a feel for the wear on the screws / nuts.
Finally, if you decide you want the machine.......I would ask them if they have a vise, collets or clamp-set they would throw-in on the deal too. Usually shops have more than they need, and are more than willing to throw in a few things to help a hobbyist. Hope this helps!!
Old 10-29-2006, 09:08 AM
Thanks very much for the response. Yes, the guy said he'd include a set of collets and a vice, and the machine also has a Bijur oiler. I did ask about the head and he said he was not sure of the history of the machine (they had 6 or 8 almost identical machines in a row, so it is believable that he doesn't remember). I am going back tomorrow with an acquaintance who is much more knowledgeable than I (incidentally, he had the exact same comments as you when I sent him the photos!)
One of the challenges where I am (S. Florida) is that there are relatively few machines down here, as there are not many 'industrial' areas. As a result, there don't seem to be as many used machines floating around. To get a machine from, say, Michigan is about $1100 + crating, so unfortunately location comes into play.
I'll let you know what a second inspection turns up. Any other thoughts, comments, recommendations?
Also, I have the serial numbers from the head and body. Is there any way to decipher these (eg, determine year, model, etc?) Thanks again!!
John
Old 10-29-2006, 09:23 AM
NC Cams is on a distinguished road
Check the fit of the ways at the extreme limits of travel.
If the table motion gets real tight as you approach the end limits of travel, they could have adjusted the slop out of the more heavily worn center travel area to "make do". THis isn't all bad just a PITA if you need to use the extreme limits of table travel.
The lean on the table/wiggle it around while you have an idicator in the quill test works here.
Look for table dings. A well used machine WITHOUT table dings suggests that the thing was well cared for or at least not horribly abused.
Run the head at min/max speeds in all gear change ranges. Run it with table as low as possible and with quill fully extended - severly worn or bent spline drive will drop out at full extension (high $ to repair).
$4k seems a bit high unless machine is in prime condition - even so......
I have an Excello in comparable shape WITH a DRO and ALL ORIGINAL with full documentation that is for sale now and I'm only asking $2900. Too bad I'm in Michighan. We'd gladly load it on your truck and cover part of the shipping for a $4000 selling price.
Old 11-06-2006, 08:28 PM
NOCARRIER is on a distinguished road
Did you buy this machine? I understand where you are coming from as I am also in South FLorida and the pickings are really slim. I ended up buying my bridgeport in South Carolina. I paid $6000.00 for it but the ways had tons of flaking and the table didn't have a single nick in it.
I knew the machine was well taken care of just by looking at it. I didn't mind spending a few extra bucks to get a cream puff.
Old 11-07-2006, 01:23 AM
handlewanker is on a distinguished road
Power knee and X with digital readout, oiler, air drawbar a vice thrown in and collets! The only thing I'd be worried about is if someone else found out about it and got there before I did, and paid the money.
If this item had been at auction then you would have to keep your fingers crossed as well. 4K, how much did you think you would get it for?
Ian.
Old 11-07-2006, 06:04 AM
Ian.
Thanks for all the replies!!
Ian - I am having a hard time figuring out 'reasonable' values, so I really don't know what I should expect to pay for it. I certainly don't expect to find a give-away, but I don't want to get ripped off either. As you can see from the responses above, even on this board of experienced people there is a wide difference of opinion about what these items are worth.
NOCARRIER - I have not bought it yet. We had a trade show last week (IBEX, in Miami) so we were pretty wrapped up in that. I am going back today to run it, and taking along a friend who is more knowledgeable than I. If you don't mind I will send you an email with some additional questions. Since you are local and have gone through this I would appreciate any help you might be able to offer (eg, who I can contact to refinish the ways if in fact that is all the machine needs to be 'pristine')
Thanks again!!
John
Old 11-08-2006, 07:44 PM
Im not sure however, if you are buying a machine with the intent of re-conditioning it, I'm not sure this is the machine you want. It seems like you need a super precise piece of equipment. Remember downtime is expensive. Personally I'd rather make a road trip for the right machine. As for the complexity of finishing the ways, I still havent found anyone in the state of Florida that does it. Keep in mind that the chrome plating on a chromed bridgeport needs to be removed, re-chromed and then scraped to fit. It is not cheap by any means.
My opinion is as follows: While tooling may be expensive I have the ability to repair, make, install modify, scavenge on e-bay, most of my tooling needs. As for repairing the machine I'm pretty much sure I can get by with most of the mechanical aspects of thing like the screws, head etc. When it comes to the ways of the machine (essentially the "heart and soul") , I have no experience nor the will to try practicing on such a rare (being the slim picking of our area) commodity in my shop. The ways are delicate, precise, rare, and actually quite demnding. I find constantly cleanining thinking about those ever so minute particles trapped in the way wipers eating my machine away.
Lots of tooling is great, but a machine that can't properly use the tooling that comes with it does not bring good karma.
Old 11-08-2006, 10:10 PM
Hey John,
You will always find a wide variety of opinions on this forum because everybody has different intentions for these machines. If I owned a production shop and relied on the machine to produce income daily, I would definitely be looking for a top-notch accurate machine that I did not have to repair all of the time. For the typical garage / small shop hobbyist, this type machine takes the cake!! I think it depends on what you plan to do with the machine, and what type of parts you expect to make on it (based on level of precision). NOCARRIER makes a lot of good points. The ways are probably the most critical feature of the machine that could cost a lot of money to refurbish. Most other parts can be replaced without too much trouble. Tell us a little about what type of work you plan to do on this machine. Will you be using it as an over-kill drill-press, or will you be machining intricate parts? The decision is pretty simple if the plan is to machine highly precise parts on it.
Old 11-08-2006, 11:11 PM
One of Many is on a distinguished road
I'd guess this to be a late 80's to mid 90's mill. Either a lot of hours, or a combination of the results of the material cut on it, bad way wipers and/or improper lubrication.
The wear looks consistant, but should be investigated with an indicator. By the evidence of swirl patterns, someone has done a masking of the real wear with an abrasive disk of some type. That much wear would break through the chrome. Rubbing with copper sulfate solution should show what is and isn't still chromed.
You could set the table in the center of the y axis and tram the head there. A 12-15" piece of ground bar atop the table parallel to the y axis could be indicated atop the bar while then moving the y axis to disclose any rise at the extremes or actual wear from center to extremes. You could also move the ram back and double check the tram at each extreme. This tells you that the table does pitch toward the shallower wear areas.
I'd also do something similar as NC Cams suggests and place the x axis at its extremes then push and pull while the y is in different locations along is travel. The saddle may shift quite a bit in the center, but tighten up at the extremes where the wear is minimal. With all that weight overhang of the table, you can again check the tram to see excessive table tilts further. A feeler gage in the y axis lifting side is another indication of severe wear on the dovetail.
The original Bridgeport specs don't even claim any better than .001. Much of that will be operator experience in getting the machine to do as expected during setup, regardless of its condition. What they did claim, as I recall was a 9" square patch on the table over the saddle. Point to point is a small part of these variables. Retaining things square and parallel once the table is moved to another position can be where a lot of precision is lost.
4 grand is about average in the Northwest for a basic manual mill. The tooling and bonuses of the DRO and draw bar do make for a decent machine, but if it is a pain to use due to its wear, I'd consider making them an offer that makes you comfortable to live with its condition. Even if you found another mill in better condition and transfered all the goods over, you may still be ahead selling the iron on its own.
The asking price and fetching price can be quite a difference if they really want it gone.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
  #11   Ban this user!
Old 11-09-2006, 05:26 AM
Thanks yet again for all the great comments.
Whichever machine I get will see very light use - probably less than 20 hours per month. Right now I do not have the need for an extremely precise machine. I will still send out any CNC jobs or items that I need more than 2 or 3 of.
One of Many - Good eye! Yes, you are absolutely right regarding the crude repair of the ways. The table still rides true and tight though so while it is not ready to go back onto a production line, I think it will allow me to accurately crank out a handful of prototype parts a month in 6061.
I did find a few companies who will refinish the ways. Unfortunately as NOCARRIER indicated none are here in FL. Nonetheless, my thought is that if I use this unit for a year and find it is not quite up to snuff I could pull off the knee, ship it out, have it completely refinish with stripping and re-chroming, rescraping and flaking, regrinding and squaring the table, etc for about $3k. I did make an offer on the machine so the net result is if they accept it I'll have a machine I can get started on, and if I have to do all the repairs I'll end up with a machine with a load of years of use still in it (basically with nearly-like-new head/ways/table), and some nice options for a reasonable price.
I'll keep you posted. Thanks again!!
  #12   Ban this user!
Old 11-09-2006, 07:09 PM
Willbird is on a distinguished road
I didnt see it mentioned, so I'll say it, make sure all of the quill feed positions work properly :-). Also alternately tighten and loosen the 4 bolts going in from the front of the head, I have seen some with broken casting in there from over tightening. I would also make sure both worms work properly (the ones that pivot the head right to left and front to back), and check the column studs too, go over the whole machine if you can and tighten and loosen each of those bolts/nuts one at a time. Check the rack that moves the head dovetail in and out
I see in the picture this is not the case, but them weirdest dang thing I ever ran into is that the worm that pivots the head right to left is an OPTION, I did not know that, one place I worked we had a bport without it....thats the only one like that I ever ran into in being around them for 30 years :-).
Bill
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
