Old 10-25-2006, 11:32 AM
plane magic is on a distinguished road
Still struggling with the Heidenhain TNC155
Hope someone can help, I bought an ex college MDI MK1 bridgeport mill which had flat batteries. I lost the parameters and the PLC program. I had to purchase the parameters and the PLC and i also bought the drawings.
I managed to punch in all the parameters and i managed to enter all the codes into the PLC ....except it wouldnt allow me to do the very first line...ie 0000...= nop and it should be 0000 = M 0
the machine is run off a rotary converter and i have ensured that the 3.5 kva transformer gets the 2 good legs and is inputing 420v and outputting 160v as per its design. this in turn runs too an Indramat 3 tr 2 driver board.
the whole panel was immaculately wired and nothing looks out of place.
when i switch on i get ....checking memory....then i have to press the CE button and it goes into what looks like the axis homing setup...this all seems normal up to this point.
When i press the green button to start it pulls in a contactor but when i release the button the contactor drops out again...with nothing happening.
I ran thrrough the wiring diagram and everything is as it should be...ie i have a closed circuit at the oil bath.
is anyone able to shed some light on the problem.
I think its my PLC but i'm unsure if i am able to test...is there a program i can run to see if the plc is doing what it should?
hope you can help
regards
Ian
Old 10-25-2006, 06:10 PM
Moderator
machintek is on a distinguished road
The PLC is burned onto PROMs. A dead battery does not make the PLC vanish.
Who had the audacity to charge you for this and the parameters?
When the battery is dead, it comes up in German that the parameters are not there. At this point press clear error CE and the parameter list will come up with a question mark for the first parameter. Start typing and arrow down to the next one. Most parameters are generic. Some are not such as backlash for each axis and travel limits + and - from home for each axis.
Press the yellow button to turn the drives on. If the drives do NOT stay engaged then you have an open limit string. You need the maintenance manual or the electrical wiring diagrams. It is possible to press and HOLD the yellow button in so you can jog off the limit switch if that is where the problem is. If an axis is on a HOME switch it comes up in a block. Pressing the green button moves each axis off the home switch, one at a time with each green press. Then each green press will home an axis.
You will need the operators manual, programming manual, etc. It is impossible to give you a course or write a manual here at this forum.
George
Old 10-26-2006, 03:45 AM
Don Diegoo
F.Sharifi is on a distinguished road
Dear Ian !
Hi!
please check with my recommendation , going step by step as below
1-push MOD and cruser dwon and wright password 95148 and press ENT to see all machine MP
2- go to MP 77 and choos the value 1 !
then turn OFF and Turn On again check machine if nothing happen go to MOD and input the password 951026 and go PLC area !
then Press EDIT key and see PLC editor , then press Q and control ask you to make copy of plc programmfrom EPROM yes or not? Press ENT to make copy , then by press END going bakc to Manual page , then Turn off and Turn On again !
if you have correct PLC prog in this way must be OK!
Old 10-26-2006, 05:07 AM
Thanks F. Sharifi.
I tried changing line 77 from 0 to 1....still the same....1 represents eprom...the prams did show setting 0 but nothing ventured nothing gained.
I work out on the oil rigs and i'm away from the machine at present but i will try your second recommendation on my return....thanks
George,
Many thanks for your time and input. Pennine Automation UK charged me an arm and a leg for them….not much change out of $800.
The machine is new to me and have never seen it run as yet
I found the parameters fine to input. The machine is an old one with a retrofit to the tnc155. I felt it was worthwhile purchase because the machine is is beautiful nick…the lecturer said it probably only ran a couple of hundred hours in its lifetime…the machine colours would testify to this. The lecturer said it was running fine until it was moved out the college and put in storage.
The machine had definitely lost its PLC. I phoned heidenhain uk and they showed me where to check such…every line was sitting with NOP…he sent me the codes on how to input them. He also sent me a copy of the skeleton for putting over the heidenhain buttons to input the program He also said when the batteries are left flat for a period of time that I’ll also lose the PLC.
I don’t have a yellow button only 2 green ones….the indramat driveboard has a small red light which comes on but after that I get nothing.
The machine has handwheels which allows movement off the axis limits…I also checked these weren’t sticky and are all free. As are the ES switches…..according to the diagram I have power going through all limit strings to the indramat.
I have the operators manual and wiring diagram which is straight forward enough to read and check.
I had hoped that there was a way of checking the PLC, as I don’t seem to be getting an output from the controller to the drive engage relays. The indramat needs a signal which I don’t seem to be getting.
What concerned me was not being able to enter the very first line of code into the PLC program yet it allowed me to enter the 600 other lines….i did this all manually and rechecked that I had every number spot on correct.
I had the heidenhain engineer out, but that was before I had the correct parameters and PLC…..he at the time couldn’t do anything without them…he is very expensive and I wasn’t wanting to get him back but I’m getting no-where myself…its sometimes worth bouncing ideas off other people
Many thanks for your time George….i suppose I was just hopeing to pick someone elses brain on my puzzle
regards
ian
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
