Old 10-20-2006, 11:09 AM
ASTRO_AL is on a distinguished road
Bridgeport Basic Q's - quickish help needed!
Hi, I have been offered a couple of Bridgeport mills.
The first is an Interact 1 series 1, the second is an Interact 2 series 2. Roughly the same price.
I'm searching for info on the differences, but just can't find ANYTHING. Can anyone point me in the right direction please - a general guide or something???
Also, the Int 2 is fine but the table has been heavily marked/cut into by a cutter. For what I need it for, it looks like it's not too much of a problem (and helps bring the price down), but what would my options be for fixing it up (if I think I need to) - best to get a replacement table? How about filing it with something & regrinding? I would guess the channels cut into it are about 3-4 mm deep by about 5mm wide(!).
Should I just pass on it?
Is there a guide for what to check when looking at buying an Interact or similar?
Thanks for any input. Great site by the way.
Old 10-20-2006, 05:16 PM
NC Cams is on a distinguished road
If the prior user was careless enough to bury a tool into the table, you can bet that he/she could care less about some of the other fine points of machine maintenance and/or care. From what I was taught, burying a tool into a table was categoric grounds for dismissal and/or dismemberment.
Then again, the previous owner may have bought the machine used and then simply turned it into a dedicated tool with special grooves for special setups. Older machines are often used in such a fashion.
It the grooves look intentional, you might use this a a negotiating ploy to get a better price. If they are/were an "OOPS", I'd be inclined to pass on it for reasons already stated. Besides, repairing old machines can really cut into the cost savings associated with the purchase of a seasoned part.
Start looking for other signs of abuse or neglect. Dirty/old grease is not a good sign. Noisey motors are also indicators that service is needed. Loose/sloppy unevenly worn ways/tables are also indicators of wear or abuse. Look under the machine and in areas that would be hard to clean. These can give a true indication of care or lack of same.
Old 10-20-2006, 07:06 PM
Moderator
machintek is on a distinguished road
Both machines have the same head. The Series 2 can supprt a LOT more weight and has more travel (18 by 12 VS 30 by 14.5). More important would be what series TNC control they have.
Many machines placed a "stevens plate" on top of a table. This is a aluminum plate with evenly spaced threaded holes for fixturing, etc. Why not cover the offending table with a similar plate to cover it and mount your vise to this.
The series 1 has dovetail ways. The series 2 has box ways.
Listen to the head run. vibration/noise equals money. Motors that do not feed smoothly at low speed need service and that also equals money.
BOOKS! MANUALS! Parameter back up?
George
Old 10-20-2006, 09:33 PM
Gold Member
Adobe Machine is on a distinguished road
Now wait a minute NC...Are you saying you have never had a tool touch your Bridgie table ?Wish I could say that ...Even some of my best machinests had accidents, including me..I can explain, teach and feel the difference between 0.05 and 0.5, but just a few times I have directed the cutter to see if it could find the ballscrew..Used Machine Tools..Look at the oiling system, look at the scraping , ways, gibbs and listen, listen..If it sounds bad, its most likley expensive to fix. Take a dial guage with you to check the machine out..Believe NO ONE who is selling the machine.Repaints are ok, but did they include the ways, dials etc..stay away from those deals..Records and the manuals are a must, no manual ? Might wanna ask some questions. Shop wisely and carefully, boat anchors in the garage or shop are not fun..
Adobe (old as dirt)
Old 10-23-2006, 09:03 AM
First thing Iwas taught to look for is "OOPS's" on the table. By Bridgeport Extrak was bought on price but it has a nice table that is pretty much OOPS free even though it came out of a production shop.
The Bridgeprot V2XT I just took posession of has NO damage whatsoever and it was used in a production shop to cut name plates for stamping dies - it is a 1998 machine.
The first think I tell a user of my machines is that if they drill into the table, IT BECOMES THEIR TABLE AND THEY BUY ME A NEW ONE. THey also have Kurt vices fitted to them and NOBODY drills onto an unprotected table.
The house rules are that you leave the machine in as good if not better condition than you found it - or you lose machine access privileges. Hence, the stuff stays VERY clean and well maintained as a result. THis may be why MY tables and machines are essentially pristine and remain that way.
My neighbor drilled into the table of my home drill press twice - first and last time. I thought he knew better so I didn't give him the warning noted above - that was my oops. That "oops" is the only major one I have in any of my current machines.
My spare Excello mill (which has rebuilt motor and is for sale with the DRO) has a couple of small table rash marks - it came out of the same shop as the Extrak. For a machine that old and with that much vintage, it is fairly OOPS free.
Mistakes from a broken/flying tool are one thing. Drilling into a table is a preventable occurance that is preventable via proper training and a bit of discipline.
Granted, my operation is a bit laid back but the "rules" are explained at the outset of one's experience here and refortified by scheduled "clean up/policing" sessions.
Interstingly, guys who let machines get sloppy dirty tend to make sloppy parts and/or have sloppy work habits. Guys who drill into tables also seem to be less concerned about craftsmanship in their work - one seems to beget the other.
My formerly "lazy good for nothing" grinder operator has evolved into a grinding artisan - he just needed some discipline and training and the conveyance of high performance expectations.
Old 10-23-2006, 09:29 AM
Thanks for all your inputs.
The controls on both are TNC145, which I think is fairly primitive? Are there any documents online with the specs of each machine and different TNC systems?
I'm now less concerned about the table and more concerned about the general health of the machine. Unfortunately, I live in Paris, France and the machine (and my workshop) are in England so it's not easy to check it out for myself. Where can I find the correct way to check runout on the spindle?
Cheers, Al.
Old 10-23-2006, 03:15 PM
Spindle runout check:
It all depends what kind of spindle nose you're dealing with.
If it is an R8, take a known good collet and mound a known ROUND gage pin in it of a decent diameter (I'd go for 0.750" dia) into the spindle. Rotate spindle by hand and check runout with a dial indicator having 0.0001" resolution.
A decent ball bearing fitted spindle should show less than a few tenths TIR. If you have runout that approaches 0.0005" or more, it could be in the bearings (not likely if they are quiet) or in an improperly rebuilt spindle wherein standard bearings were fitted and the spindle ID was not ground in place afterwards.
If it has a MT or some other taper, you need to do the same thing with a known GOOD tool holder that is runout free. THen do the same sort of test.
A spindle rebuild can be costly, especially to do it right so as to regrind the spindle taper properly to re-establish the tool axis to be concentric with the axis established by the bearing rotation axis.
Some guys think that a bearin R&R is sufficient to "rebuild" a BPT spindle. Sorry, NOT. Due to the selective fit process that was used by the OEM to build spindles via the selective fitting of bearings to spindles, a bearing R&R will only fix noisey bearings at best. It will NOT guaranted a properly cutting spindle that is free from runout.
That pretty much covers it....
Old 10-23-2006, 06:45 PM
gus gus is offline
gus is on a distinguished road
re
both are solid machines, but heidenhain no longer support the 145
monitors die, and can be expensive
they are 2 1/2 axis machines with a 1000 line programming limit
I have 3 similar machines, but I would tend to try and fine a slightly newer one, as the 145s must be 20 years old now
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
