hello all. i recently purchased a r234. i have gleaned lots of tips on troubleshooting this machine on this board. i have a problem with the enable drive . at startup, the diagnostics onscreen show no errors. doing the pushbutton test routine shows no errors. i have air pressure. all fuses check out. the enable drive button keeps showing the red led. the drives wont enable. on the bsp board, led #3, led #4 flash.i have removed the boards and cleaned the contacts. no limit switch is triggered. the oiler reservoir is full. |
| Is your emergency button pushed in? Once it finishes booting, and you press enable, do you get an error message? George
| That would give you a axis limit error. Have you looked at the boss event long and fist event log? Have you checked the status of the FMDC LEDs? The two green ones on the end should be blinking at a different rate from each other. George
| My R2E3 does that fequently, and most of the time it is the Z limit switch. I figured out that little quirk, now if I could get the rest of it to work.....
__________________ "ain't much that can't be repaired, rebuilt or replaced..." |
| It means the FMDC has NOT passed its self tests on bootup. Check your power supply to the FMDC, check all connections, make sure all chips are seated correctly, and pray that it comes back to life. George
| Did you get it working? I have a R2E3 and when hooked up to my rotory phase converter, I had to make sure the generated leg was not going to the 24v power supply. The E-Stop button would only get about 19v and control would not see it. Last edited by jonah332; 11-04-2006 at 08:24 PM. Reason: typo |
