Old 10-13-2006, 01:49 PM
*Registered User*
jho5820705 is on a distinguished road
BP Series I axis problems
Hi! I am new to CNCzone and CNC machines. I just purchased a BP Series I and got it wired up. Initially the Z-axis did not work. X & Y axis would jog fine. I pulled the transistors and replaced a bad one on the z-axis but it still does not work. Now the y-axis has a problem. The stepper motor seems to have power but will not turn the pully even with the belt removed. Did I mess up something when I changed the transistor? Or is this just another problem cropping up? Any help would be appreciated.
Old 10-13-2006, 03:26 PM
NC Cams is on a distinguished road
Frankly, if the axis worked before a repair and now doesn't now
, it is a good estimate the something got hurt in the process of "fixing" what ultimately didn't get fixed.
Try pulling the power transistors and bench testing them - if they pass current, it is probably in the drive circuit. Also, get hold of a wiring diagram for the control circuti and see if you have power going to the drive circuits and ultimately to the power transistors.
Swapping parts willy nilly can get stuff up and running but it can also result in more damage. This is especially true in "legacy boards" that have been heated and cooled and start to semi-conduct thru deteriorated solders or old, possibly frayed wires. You can even fry transistors via improper handling.
You're going to have to troubleshoot the circuit in an organized, logical fasyion to find out what's gone wrong - that is, unless someone had the exact problem you did and knows the 'silver bullet' fix.
Possible but I wouldn't count on it.
Welcome to the challenges of fixing/resurrecting legacy equipment.
Old 10-13-2006, 03:41 PM
*Registered User*
I have ordered all the manuals for the machine and am waiting for them to arrive. I have traced the wiring and tested for signals and found the bad transistor in the z-axis, power going in none out. I have power to the y-axis but not enough to turn the motor. Guess until I get the manuals I will have to wait to test further. I am not sure what voltages I should have where.
Thanks.
Old 10-14-2006, 10:05 AM
The manuals will probably have the intereconnect wiring but I'd be surprised if they have circuit board wiring for amplifiers or drives.
If you have a functional driver/amp, you have a leg up. Start by comparing voltages at the gates of the drive transistors of the DOA board versus that of the good board and work your way back. BE CAREFUL as you're surely running out of bullets.
You might find that you may have to remove the pass element (drive transistor) as a short here can load down the drive and give bogus voltage readings. Look for burned or broken traces - perhaps even fried parts. Even a simple shorted diode can cause HUGE grief.
If you don't have voltage at a gate when you should have, or vice versa, that is a strong indicator that something is awry in the drive circuit.
If you did a lot of moving or R&R'ing of stuff to replace the funky transistor, you could have broken or cracked a trace on an old board. These can be a nighmare to find if they can be found at all.
If you can get a schematic for the amplifier drive, you'll be miles ahead with regard to troubleshooting your problem. Simply reading voltages for a circuit that you have not clue on how it works is a really hard way to fix something.
Sometimes it is simply easier to start replacing transistors (if you can find replacements which can be tough to do if they are old clunky darlingtons). I did that on some small power supplies and lucked out.
On more compicated boards, however, you really need a schematic to help you figure out what's wrong. Shots in the dark are not always on target.
Power going in but not enough going out suggests that the base drive current flow on the transistor (assuming it is a PNP or an NPN) is insufficent or totally non-existent. Then again, if the drive isn't pulsing or is pulsing out of phase, the motor won't commutate which points to a more complicated drive mallady.
Might want to locate someone who has experience with fixing amps like those you have. Might be money well spent, especially if you're not electronically proficient at reverse engineering circuits.
Old 10-14-2006, 10:54 AM
Moderator
machintek is on a distinguished road
Sound like an older BOSS machine with stepping motors. Yes, the complete maintenance manual has all the board schematics.
The drives are very wierd. None of the fuses associated with the drives should be the screw in type. They develop a high resistance and you will see the fuse material melt out of the ceramic fuses. They were replaced with snap in type.
The current (DC) should be set to 8.0 to 8.2 amps using the ACC board. Never connect a meter or remove a meter or fuse with the drives on. You wil blow a transistor. Running into a limit at rapid will usually blow a transistor unless you have the SMS board.
If your voltage on T2 (back cabinet, top) exceeds 63 VAC, you will blow transistors like candy.
Many people have dropped a screw or washer onto the terminal strip for the motors and then that axis behaved like it had a blown transistor.
You do not want to know where the bridge rectifiers are!
Once set up correctly, I have these machines running very reliably.
It is normal for the Z axis to rapid up, hit the decel and feed the rest of the way, usually .200 inches. If it does not do this, it may mis-position.
George
Old 10-14-2006, 10:59 AM
Moderator
By the way, the transistor Bridgeport called out was a 2N6547. At rest the voltage at fuses 12, 13, and 14 was between 9 to 10 VDC, current 8 amps.
At rapid the voltage would rise to ^)VDC and the current would drop to 2 to 2.5 amps.
Heat and age affects the motors. You cannot take them apart. As they age and the magnets decay, the power (torque) diminishes and the rapid current goes up. I can get more life out of them by turning down the rapid rate on the RCK or ZCK board.
George
Old 10-14-2006, 12:09 PM
*Registered User*
George
You are right this is a BOSS 6 machine. The transistor is changed is one of 4 on the heat sink behind the SMD boards. I didn't touch the transistors for the y-axis so I can't understand why that is not working correctly. It will job if the switch is in step but not in jog, 1, .1 or .01 positions. The display does not give me the y or z positions when selected in jog mode. It does display the x position. I am beginning to think that I may have a controller problem also. Maybe it is time to upgrade to MACH3 and Bob.
Old 10-14-2006, 12:43 PM
*Registered User*
Just checked the voltage at Fuse 12, 10.2V at rest and 56V in rapid traverse. Fuse 13, 9.1V at rest and 12.3V in rapid traverse. Fuse 14 is .215V.
Old 10-14-2006, 04:04 PM
Moderator
X axis is normal.
Check fuse 17, the Z axis AC fuse.
Also in setup you CAN display the axis position. The keyboard is color coded for what mode you are in and you can press the appropriate key to display that axis.
Does not sound as if the Y axis is really moving.
If the axis does not move and you hear a whine it is actually the motor oscilating between poles usually due to a blown transistor.
A quick check is to put that axis in step and step it. If it steps forward, forward ,forward and then backward, it has a bad transistor.
George
Old 10-14-2006, 05:28 PM
*Registered User*
It appears that the y-axis has a blown transistor, it moves forward 3 steps and then hesitates. I can't see it moving in reverse but it does not move forward on the fourth step. I don't have any blown fuses that I can find, but could not find a fuse labeled 17. There were three fuses in the power cabinet that I checked also and they were all good. I guess I am going to have to wait and hope that the manuals will show me where everything is. There are a lot of labels that are missing or unreadable in the cabinets.
Old 10-14-2006, 08:56 PM
Moderator
If I remember correctly Fuse 12, 13 and 14 were X Y and Z DC side.
15, 16 and 17 were X Y and Z AC side of the bridge and were in the back cabinet.
George
  #12   Ban this user!
Old 10-15-2006, 12:48 AM
bbuonomo is on a distinguished road
George
THANK YOU! This answers why I blew 2 power transistors this week. I was jogging Z and when I jogged Z + and hit a limit switch, it stopped working (aka blew transistor). I'm guessing the BOSS5 controller on my system used to handle the decel, but now I'm using MACH3 and a BOB Controller (Hillbilly's board), it didn't decel and zzzaaaappp.
BTW, I'm very happy with the BOB Controller and MACH3. Still a lot to learn, but I was able to run some code today to test it all out and all seems good so far. Still learning how to set offsets and setup in MACH3.
Thanks!
Brian
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
