Old 10-03-2006, 09:24 PM
NC Cams is on a distinguished road
4th Axis addition - V2XT
Want/need to add the fourth axis 'option' to a V2XT that i just bought. Version is a 1998 with the DX32 with BMDC controller card.
Short of duplicating/buying the OEM pieces/parts, has anybody done a retrofit/4th axis upgrade to a 3 axis machine?
What did you use and where did you get it short of buying off of Ebay? Need suggestions for axis/indexers (model numbers and makes).
Any advice on where to get the material for the harnesses (cable, connectors/sockets for plug-in wires on AUF and AXSBOB cards, etc)?.
I do have the factory schematics.
Old 10-21-2006, 01:34 AM
RedGTZ's Avatar
RedGTZ is on a distinguished road
I'm also looking at doing the same exact thing but with a TorqCut 22 from Bpt, the machine is like new and I would have parts to do in 4 axis once in a while but I want to keep the cost of this install as low as possible
Thanks for any inputs!
Old 10-21-2006, 10:34 AM
As my situation is essentially a 'retirement' project, my cost criteria is exactly the same.
Cheapest alternative I've found so far is Troyke who made the "table" for Bridgeport's 4th axis as the OEM. BPT then did their own system drive integration/packaging. BPT did not buy a pre-packaged kit as you now can do now from Haas or SMW or Troyke - but for a real co$t.
Basically, Troyke sells the table/axis and then you start adding motors, cables, drive belts, etc to them to make the full 4th axis. You have to buy your own servo amp drive too. It doesn't get inexpensive once you get a fully functioning system - hell, Troyke even charges you for the frigging cable and that isn't cheap (according to their on-line price sheet).
In your case, you have AC drives for your servo's hence you really want a "matched" amp/motor package for the 4th axis. From what I learned so far, you do NOT want to go mixed mode (AC VMC, DC 4th axis or vice versa).
ALthough AC drives are much more modern and have all the more modern advantages, they do have added comlexity. Reason: a separate path of communitication has to be established between motor and drive so as to affect proper commutation.
This is in addition to servo position feedback. This means matched motor/drive combo which surely ups the cost ante and the complexity and reduces flexibility of choice. Depending on your skill level, it may simply be outside the realm of DIY integration for you to create your own 4th axis AC system. Recall that you or someone has to tune it and tell the DX32 that it is there and do so properly.
SO far, the prices I've gotten range from $5700 (9" table only, no wiring or motor or drive) plus $1.3 to $1.8k for a motor plus the encoders plus the cabling (prices TBD) - probably $8k~$9k when it is all said and done.
Just to find the proper MIL connector that plugs into the prewired cabinet essentially turns this into a PITA project AND the schematic is NOT that easy to read/figure out regarding which pins are which on the prewired MIL connector that should be in the cabinet.
I got an $8K "estimate" for a plug and play system from Haas. But they are not at all quick in responding to my formal RFQ. And even when I sent them the schematic and all the motor and servo amp info and the controller info, they seemed reluctant to want to prewire it for me.
In light of the fact that you are probably running an AC based servo drive system on your machine, you're options for an aftermarket system are more limited than mine (DC system on V2XT with prewired cabinet).
Even so, I"m learning that adding a 4th axis drive to anything that is of a "legacy" device such as our units turns into anything but fun and games.
I can't wait to see what fun is in store for me with my "4th axis, the DX32 software automatically recognizes that is there" when/if I get a 4th axis. Is there any reason why I should dream/hope this will happen???
Old 10-21-2006, 11:20 AM
Moderator
machintek is on a distinguished road
Careful. The Torque cut 22 had DC motors. SEM on X and Y and a PARVEX on the Z. Spindle drive was Yaskawa AC type.
The TC1,2,3, and 4 had the Yaskawa AC drives on everything.
George
Old 10-21-2006, 11:53 AM
RedGTZ's Avatar
Arrow
Thanks for the quick reply guys.
I dont really need sychornized 4th axis for now but rather a positioning 4th axis, would this be an easier install??
I think the project will be put aside until the next machine gets in the shop... it seems to be a real pita to get all this working right and I have only a basic knowledge of all that integration stuff.
My TC22 was prewired for the 4th axis but the drive and other components are not there so that would be a huge investment compared to the price paid for the machine...
I'll get in touch with you guys for sure if I ever decide to make this dream a reality. You seem to both have a lot knowledge with the Bpt machines
Thanks again!
Old 10-21-2006, 10:26 PM
The servo amp is a "cheaper" part of the project when you lay out the whole cost factor.
Motion Science and Advance Motion Controls sell brush type DC servo amps that will readily work pretty much as bolt ins. The AMC's are between $350 and $395 each and they should bolt up to the appropriate wires that are already in the cabinet.
The axis hardware along with the cable from the axis to the power cabinet are the pricey items however.
Sorry about the bogus info on the DC vs AC for the TC22 servo motor - I was looking at the VMC 800/1000 wiring diagram which is AC motored.
BE REAL CAREFUL when buying used 4th axis. I've seen many that seemed like a deal - only to find out (in time luckily) that the motors are AC and I need DC.
Apparently you and I are looking for the same entity and they aren't that plentiful. For the time being, Haas still custom makes DC fitted motors but supposedly that will last until years end when they are supposed to quit.
I guess that it would not be THAT hard to change an AC motored servo over to DC from a mechanicla standpoint. However, the PITA that you'd have to go thru to get a motor, make sure it had proper encoders, and a tach could be more trouble than it is worth. Yes you can shop on Ebay but 100vdc servo motors with tachs and encoders don't seem to be at all plentiful.
My research, Machintek George's help plus advice from another tech indicate that once you have the thing wired, it is pretty much plug and play. The DX32 controller automatically senses the 4th axis and away you go.
Yes, the cabinets are "prewired" but I still can't find the wires that go from the amp to the output connector in my cabinet - I found the shunting relay but can't find the wired 'tween it and the amp. Not a biggie to run but why bother disturbing a harness if you don't have to.
My knowledge about the systems was developed as a matter of general interest in concert with a need to repair/service my mill and not having the cash on hand to simply pay to have it done. Actually, I got a bit too involved in the reverse engineering of the electronics but is has not been a waste of time and effort.
When you consider what it costs to build a V2XT versus what they want to fit it with a 4th axis, the option HAD to be a real money maker. If you take the time to study the wiring diagram and find the wires (thankfully BPT labels stuff real well), it isn't that hard to figure out what's going on.
How to find and get a deal on the axis, now that takes a real gift and/or a huge chunk of luck.
A positioning 4th axis might be easier and perhaps cheaper but for a little bit more, you can go to the full axis and be oh so much more flexible and/or precise.
As my dad told me when I was old enought to drink, "drink top shelf, it tastes better and you won't be as sick in the morning". This translates to "buy the best you can't afford, you won't be disappointed with the performance" when it comes to buying equipment for my business and/or hobby interests.
Old 10-22-2006, 12:25 PM
NEATman is on a distinguished road
machintek-
If one already had the SEM motor with encoder and the same model drive as on the V2XT, it would be straightforward to use this motor and drive a 4th axis? Does the cabinet supply the DC power needed for the amplifier? Or would I need a seperate powersupply for this additional drive?
NEATman
Old 10-22-2006, 09:32 PM
The DC buss on the V2XT supplies power to ALL the axis drives (100-105vdc if memory serves correct).
If the motor on the 4th axis that you're using is compatible with that voltage (SEM or whatever), it should run fine off of the V2XT power supply. If you have a4th axis motor that is a twin to the V2XT drives, you are in fat city.
There is a MIL spec connector on my V2XT that is already plumbed with the power and feedback/control circuits needed for 4th axis work.
The wires for the 4th axis amp are coiled and ready and taped to the back of another amp. When/if properly connnected and the parameters in the BMDC configuration file propely set, the 4th axis should "plug and play" if the 4th axis connector cable is appropriately and properly wired.
Old 09-25-2007, 07:01 PM
RedGTZ's Avatar
Just bought my 4th axis yesterday, I had to jump on this one
I did a post about it and about the install, I'll update it as I'm going thru the whole process.
http://www.cnczone.com/forums/showth...853#post346853
Any advices? I got a lot from that thread alone so maybe you got something new to share NC Cams or Machinetek
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
