10-02-2006, 10:11 AM
Are you planning on using the quill as the z axis for the router? It would be difficult to do that. You would need to make some sort of bracket that clamped to the bottom of the quill and then mount your router to it. If you are going to use some other method for the z axis I would pull the whole head off the series 1 and make a bracket which would bolt onto the neck. Then you would have your z axis slide or whatever mounted to the neck and you would be good to go.
Matt |
