Old 09-18-2006, 04:14 AM
jmorris@mailmds is on a distinguished road
EZ-Trak DX2 Startup Questions
We just installed a used DX2 and did the 480 to 208 Volt power conversion.
When the PC tries to boot, we get the following displayed on the monitor:
Award Modular BIOS v 4.51PG
Green PCI/ISA System
Pentium-S CPU@75MHz
Memory Test: 8192K OK
Plug and Play Bios Ext. v1.0A
Detecting IDE Primary Master... None
CMOS Checksum Error. Defaults Loaded
Press F1 to continue Del to setup
09/04/97 - i430TX-W83977-2A59IA1BC-5U
A Machinetek post suggested checking/replacing the Bios battery. We have found that it does indeed need to be replaced. Will this alone solve the problem or do we need to reconfigure the BIOS? Any suggestions on doing this?
Is there a way to connect a regular keyboard to have full access to the controller? Where is a good place to buy a manual?
Thank you,
Jon
Old 09-18-2006, 08:59 AM
NC Cams is on a distinguished road
With the battery dead or dying on the motherboard, the BIOS won't stay active. Thus, each and every time you try to boot the machine, the thing will ask/force you to reset/reconfigure the BIOS to get the parameters appropriately.
When/if you replace the battery, the boot-up problem should go away.
When you reset the bios, make sure that you turn LBA "OFF". Also set any 'write cache before exit' to "ON".
Look on the back of your control pendant. Advise if there are DIN pins there - there should be 3 or 4. If there are, you can plug in a keyboard there buy you also have to "swap plugs" back and forth - some of the keys on the small OEM keyboard aren't easily found on the regular computer keyboard.
I have a diagram at work that I have to follow to make the swap so I unfortunately can't advise readily right here and now.
Manual: which version of software do you have??? There are versions 5, 6 and a beta of ver 7 that some folks have access to.
Check on this website via an "Eztrak" search - I seem to recall someone posting a copy of a manual as a PDF attachment at one time or another.
Old 09-18-2006, 11:28 AM
Moderator
machintek is on a distinguished road
Yes, once the BIOS/CMOS is corrected, the machine should boot. Because you have a baby pentium, I am suspecting that you may have a CIB (control in a box) either a Cutler Hammer, or a newer BMI. The mother board is a half size, all in one, industrial unit. Some have a coin style lithium battery and some have a DALLAS REAL TIME CLOCK chip. the again, you may have a old pentium. You have to look.
Did you want a programming manual or a maintenance manual?
Again, it would need to be specific to your level of software or the internals of your machine.
George
Old 09-18-2006, 08:15 PM
First of all... Thanks for all the help. The machine is booting up now and we have a standard keyboard working.
When we try to home each axis, the Z axis runs away. We removed the front cover and it looks like there is a clamp that is used to engage the Z axis. The nut is so tight on the ball screw that we cannot rotate it up to the clamp. Likewise, the quill feed is so tight that we cannot lower the quill. To make matters worse, we do not have a quill feed lever. The machine did not come with one. We thought that it would not be neccessary with the three axis machine. Any suggestions on how to get these two together?
Because the Z runs away, we have not been through the X and Y yet. However, the X and Y encoders seem to be working fine.
We do need manuals, How can I tell what level of software we have?
Many Thanks,
Jon
Old 09-19-2006, 08:23 AM
Steve@Reliance is on a distinguished road
I just ended up with a manual for a Sereis I DX. I have an SX II. What are the differnces in the machines and controls, And will this manual help me?
Crashing Sucks!
www.reliancemachine.com
Old 09-19-2006, 08:28 AM
Hit F8 and hold it while booting. This will ask you if you want to load each and every program as you go thru the autoexet.bat file.
Say NO to anything that looks like it has the word EXTRAK or EZLOAD in it. When finatlly booted at the O/S level, you should see a C:\ DOS prompt.
At this point, anyone proficient in DOS should be able to 'see' the date version of the Eztrak software being used.
If you're lucky, they loaded DOSSHELL which when typed at the C:\ prompt will enable you do have a WYSIWYG screen that makes this process much easier. If not, it can be loaded separately off of a DOS 6 install disk.
As an alternate method, you can also exit to DOS from the Eztrak software but I can never rememeber how to do it.
Sounds like you need to undo some hamfisted modification that the previous mill owner performed.
BTW: you'd better plan on changing the current limiting breaker to the spindle motor. When you convert from 480 to 208, you DOUBLE the current draw potential to the motor. Initially, the breaker will fault when the motor sees some loading.
We simply reset ours and kept on cutting. HOWEVER, Do that ONCE too often and the damn thing will eventually NOT reset. Change the breaker NOW or else you will have to do it later, usually in the middle of a hot job when NOBODY IS OPEN who has the breaker.
If your machine is like ours was, it uses a Telemechanique (sic) breaker which was NOT AT ALL easy NOR CHEAP to find.
Old 09-19-2006, 09:01 AM
NC CAMS, I will try your suggestions for the software revision/manuals.
I did change out the current overload. I sourced an Allen Bradley part the was very available, affordable and a direct replacement. You will need 1 each of 193-EA1FB and 193-EPM1.
The Z axis problem is now solved. Each axis seems to be fully functioning, i.e. limits, jog, homing.
The original keyboard does not seem to be working. I have connected a wireless keyboard and it works fine.
At this point, the spindle is not turning. I think it is due to a low lube alarm. The tank is empty. I have a 5G bucket of Mobile DTE 26. Is that okay for lubing the ways?
I would also like to find hardware manuals for this Bridgeport EZTrak DX2 machine. Does anybody have suggestions on where to find them?
Old 09-19-2006, 09:13 AM
It looks like I have the EZTrak software version 3.85.3. Does anybody have a suitable software manual for this?
Old 09-19-2006, 09:20 AM
A maintenance manual would be much appreciated too!
jmorris@mailmds.com
Thanks!
Old 09-19-2006, 03:14 PM
The software version I have is dated mid 1990's and it is version 5.
Version 3 software might be an early Southwest Industries machine. MACHINETEK George would be the expert who could verify this or not. I could be wrong.
Have you tried EMI yet??? Their stuff is highly regarded for value (by them) so expect to pay heavily for the manual(s) from them. If you give them the serial number, they should be ablt to give you more insight into what generation machine you have - if you can get past the secretary.
In the mean time, try Machinmanuals.net.
Old 09-19-2006, 09:07 PM
Moderator
The DX and SX were very different in the motherboard and the DX had a hard drive. The version you have is the first good version for the 3 axis machine. The Southwestern Industries machines did not have a CRT/monitor. They had an LED readout. Later they were sold as Proto traks.
A 3 axis SX machine is rare. I typically do not go past version 3.02 for an SX machine, 2 axis. It just runs better and it has a screen saver to prevent burn in of the CRT.
Versions, 5, 6 and 7 (beta) have more bells and whistles as the numbers go up, such as mill arc slot, importing DX files, and engraving.
Keep an eye on your parameters (backlash, pitch error, etc). The versions prior to yours had a habit of changing them for no reason.
As the machine boots and the BMDC finishes counting down, the version will be briefly displayed. I know the EZPATH will display the version by pressing the minus key after homing. Do not remember if the TRAK will do it, but I do not think so.
Try this though. Go to RUN, load a program, and press the minus key. It will display the program in G and M code as converted by the BMDC internally. You see, the machine is really a G & M code machine.
George
  #12   Ban this user!
Old 09-19-2006, 10:49 PM
Topping off the lube reservoir solved the spindle problem. Apparently, it is interlocked to a low level sensor. The spindle run fine and sounds pretty good. Now, all I have to do is figure out how to program it and get some more Kwik Switch 200 tooling.
Does anybody have electronic version of software manuals?
Thanks for all the help so far!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
