Old 08-27-2006, 09:27 PM
kramstr's Avatar
kramstr is on a distinguished road
Bridgeport Starter Assembly Wiring
I recently purchased a Bridgeport CNC Series 1 Rigid Ram. I'm converting it to PC/Mach3 control using Darek's (Hillbilly) BOB.
While cleaning it up I found that the wiring in the manual starter box was disconnected. I'm hoping someone could help me get this thing wired properly.
Thanks in advance,
Mark
The wires in the box are numbered as follows:
39 - White
40 - White/Black
128 - Black
135 - Black/White
194 - Red
214 - Red/Black
218 - Orange
219 - Orange/Black
221 - Blue
229 - Green/Black
230 - Blue/Black
Below is a picture of the back of the switches with the jumpers that were already installed. I added wire numbers to the photo.
Old 08-28-2006, 12:18 PM
markhas is on a distinguished road
Mark,
I had the exact same problem last weekend. Here are 2 images of the inside of my starter box. On the right is the 3 position switch. On the left is the E stop and spindle enable. I hope this helps. Drop me an e-mail and I'll walk you through it if you want.
Mark Hasenberg
ID:	21929   Click image for larger version
Old 08-28-2006, 01:39 PM
kramstr's Avatar
Mark,
Thanks! That's exactly what I needed.
Mark Strieter
