  #13   Ban this user!
Old 09-07-2006, 07:32 AM
creep_pea is on a distinguished road
Cheers Snakebit I'll have a look at it later
  #14   Ban this user!
Old 09-07-2006, 09:00 AM
sdeering is on a distinguished road
I slid the table competely off and also removed the Y under that. An engine hoist works well for the table. There are lost of lube points under there.
Stephen
  #15   Ban this user!
Old 09-07-2006, 04:33 PM
Managed it just sliding it to the rigth hand side, I used a prop to take the weigth of the free end.
Found the x axis ball screw meter to be blocked the rest were ok.
Thanks again
Chris
  #16   Ban this user!
Old 09-07-2006, 08:02 PM
snakebit95 is on a distinguished road
Glad it turned-out to be an easy fix!!
  #17   Ban this user!
Old 10-16-2006, 01:07 AM
Astroboy is on a distinguished road
Talking BIJUR info just to have on CNC Zone
I fixed my Bijur pump (was a TMD-5 model) and lubrication system on my BP series 1 CNC with help from:
1. Bijur: 1-800-631-0168 talked with Clarice X5473 (very nice) faxed me service instructions with part list and diagram
Parts used:
B9834 Motor cover gasket $1.53
B8197 Resevoir gasket $3.03
B5220 Leather cups (need 2) $2.65 each
S-109 Filter group $17.37
H0-402 "O"- rings (bought 2) $1.16
Make sure that everything on the inside of the Bijur unit is spotless, and put some oil in it and make sure it works. Make sure that you write down the wiring connections before you take it off the machine.
2. General Bearing 1-800-373-2105 or 1-323-588-2101 - talked to Bob (last name Fytman I think), who is a factory rep for Bijur. Sells the metering units (little brass items located at places in the line. There are some on the left side of the machine. Check those first. Make absolutely sure that the line going up and back (to spindle) is working! I used part number 185502 (bought 3 for $7.37 each). Metering units have numbers on the side: 3/0 lowest flow, 0 0 next lowest, 0, 1, 2, 3, 4, 5 in order of increasing flow. Check the number on the side and order the same number. Bob can help you figure out what you have.
3. ME
I slide the bed (~340 pounds!) off to the left of the machine and supported it on a table and an eyebolt on the bed with a pulley system up to the top of my garage. Was able to get to each metering unit. Was able to clean out all the chips and other gunk under the bed as well. Check each one for flow, and replace if there is not some flow. Clean out oiling grooves on ways with Q-Tips and any orfices that bring oil to the grooves (mine were full of sludge). Even the gib should be taken out and cleaned because it has holes/slot in it that was gunked up. Only draw back, is that now that all are working I get lots more oil on the floor.
Solution: Go to dollar store and get cheap aluminum cookie sheets and place on floor and machine base. I refilter the way oil using coffee filters (also bought at dollar store) and use it on my manual lathe ways (much cleaner than chips and works better than car oil). I would not reuse it in the Bijur unit because those metering units get clogged with small particles.
My machine acts like it is much smoother with the bed and cross slide moving much easier now.
Hope this is useful to all! - John
  #18   Ban this user!
Old 10-17-2006, 03:29 PM
NC Cams is on a distinguished road
Astroboy: check out the properties of Dexron III ATF. It has anti-rust and anti-oxidation agents that can help ungunk sludged up lines and passage ways.
We've used it in a pinch for spindle oil, way oil and goodness knows what else. It, too is better than engine oil because it has agents in it the keep rubber o'rings from swelling detiourating - motor oil doesn't.
Cheap and easy to get, too.
Recycling oil as filtered via coffee filters may remove particles but other chemical contaminants may remain. I'd be real learly of filtering oil that has been thru the system because you don't know what it picked up. Besides, the red color makes it real easy to see if it is ATF or oil from someplace else that you NEED to be concerned over.
  #19   Ban this user!
Old 10-17-2006, 04:05 PM
Smile Not a bad idea
I had not considered ATF fluid. Some brands seem to have a really nasty smell to them, however. I bought a quart for one of our vehicles, and I had to put it into two zip lock bags to reduce the smell.
One concern that I would have is that Vactra 2 has substantially higher viscousity which would make the thin film of oil on the ways thicker than ATF. Because it is thicker, it makes things move more smooothly than a lower viscousity fluid, and would have less wear. Manual transmissions usually have 90 weight gear oil in them for this reason. Automatic transmissions have other reasons for going to thinner oil.
But a quart of ATF is probably substantially more inexpensive than Vactra 2.
And ATF addititives would stop rust and other things. Since I always use RE-LI-ON oil as a cutting fluid, I never have to worry about rust, but for those that use water based coolant/cutting fluids, then reducing rust would be a good feature.
Interesting idea - Thanks - John
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
