  #13   Ban this user!
Old 08-23-2006, 08:14 AM
L98FIERO is on a distinguished road
Another question; Kluber has these high-speed greases;
ISOFLEX LDS 18 SPECIAL A
ISOFLEX NBU 15
ISOFLEX NCA 15
Klüberquiet BQ 72-72
Klüberquiet BQH 72-102
Klüberspeed BF 42-22
Klüberspeed BF 72-22
Which one is the right one?
LaVerne
  #14   Ban this user!
Old 08-23-2006, 11:27 AM
Bump!!!
  #15   Ban this user!
Old 08-23-2006, 04:02 PM
NC Cams is on a distinguished road
Kluber is like the, or THE super premium synthetic bearing grease, especially LDS18.
When it comes to ultra high speeds, Kluber is like super good stuff.
Bridgeport oem grade bearings were lubed with Andok C which was a good general purpose grease.
They were lubed at the factory and some 10-15 year old or older mills are probably STILL running with Andok C providing the stuff never got overheated or contaminated.
Re: washing bearings. A factory wash and fill of grease is hard to beat. Be it Fafnir or NSK or NTN or Koyo or whomever did the OEM Bridgeport service bearings, you were pretty much assured of as good a service bearing as the stuff that was put in the machne when it left the BPT factory.
Regarding the "...the manufacturers don't always do a great job of cleaning the bearings either..." comment, all I can say is HUH?????
The factory clean and grease fills of the bearings that we did for the OEM's we supplied bearngs to/for worked well.
Be it the company I woked for or the companies we supplied to/for, ANY bearing supplier would have a hard time agreeing with that statement.
Sort of like saying, "...when did YOU quit beating your wife or kids???.."
  #16   Ban this user!
Old 08-23-2006, 08:24 PM
I picked up the Kluber ISOFLEX NCA 15, a 50 gram tube is $55 CDN though I found my local supplier is a bit pricey compared to some others. Way I figured it, if I ever need to replace the bearings on another mill, I'll have grease.
About the marks on the bearings, are they to be aligned? I've found that some of the info I've found isn't neccesarily accurate
LaVerne
  #17   Ban this user!
Old 08-24-2006, 08:27 AM
Cleaning agent for bearings: A spray solvent like Brakecleen by CRC is what I use/recommend. DO NOT SPIN DRY THE BEARINGS WITH AIR.
Don't just shove the grease in as if you were packing wheel bearings or pickles into a jar, use a syringe and instert the grease into the inner and outer raceways. Put in a little bit and rool the bearings around in hand to distrubute grease on the balls/cages. Then insert the rest. 30% fill is plenty.
When you start using the spindle, start it real slow and let it run that way in pulsed operation with longer and longer run times. This channels the grease nicely as opposed to flinging all over hell and back.
Watch for ANY signs of rapid heat rise - if this occurs, stop and find out why, IT WILL NOT GO AWAY ON ITS OWN.
Traditionally, any alignment marks should be aligned. These were also used to mark the high point of eccentricity in the bearing raceways. It used to be that you could orient the spindle eccentricty and bearing eccentricity to minimize ID grinding amounts.
BUT with the way they make bearings anymore, it is pretty hard to do that trick anymore because the raceways are so concentric - at least the good ones.
  #18   Ban this user!
Old 11-20-2007, 05:26 AM
bhavesh is on a distinguished road
problem in spindle new braring noise
hi,
every one
i make 10,000 rpm spindle but not running proper it very noise in bearing and some vibration so please give some feed back
my spindle data
housing OD = 40 mm
shaft dia = 15 mm
baring is 6002 angular contect koyo japan not precision pair bearing
when i runing speed 2000 rpm in spindle some noise
thanks
  #19   Ban this user!
Old 11-21-2007, 07:23 PM
"NOise" is typically caused by damage or faulty efforts - which you have is hard/impossbile to determine.
A 10,000 rpm spindle SHOULD be used with precision bearings - you need ultra precision to run at that speed and for the parts to survive.
A 6002 is NOT, NOT, NOT an angular contact. A 7002 IS an A/C. They are NOT, NOT, NOT a one for one interchange. They are the same size but NOT the same bearing!!!!!!
If you NEED a 7002 and used a 6002 in its place, it would not be a surprise to experience dissatisfaction in the performance of the device.
Frankly, ;you do not give enough information to diagnose "bearing noise".
Sometimes, this can be caused by improper assembly (damage occurs at installation).
Sometimes by improper design (no preload, not enough preload, wrong preload, etc)
This can perhaps be because of the use of the wrong type of bearings - Examplke: use of ball bearing when A/C is needed or something like that.
  #20   Ban this user!
Old 11-21-2007, 11:56 PM
i wat to use pair bearring for spindle
i check some spindle in use for p4 or P2 class A/C bearing.
so i deside i use in this spindle 7002CTRDULP3 Make RHP bearring A/C
but i dont know desigen and tollrance shaft dia bothside and housing ,bothside or spacer and spring tenson . for preloaded desigen.so any desigen darawing ,data
and tollrance for bearring fittin..
thanks
bhavesh
  #21   Ban this user!
Old 11-23-2007, 08:11 PM
If you need ISO P4, you should NOT use ISO P3 - they are NOT equivalent in accuracy, they are not even close. P3 has about 2x the runout tolerance as P4.
You have DUL bearing. Do you need DUH or DUM??? IT makes a difference. What about fit? Should it be DU, or DB or DF. You don't say. Do you KNow????
If you have NO idea about your shaft or housing accuracy, you may NOT be installing things back properly or correctly. Machine tool fits are NOT always simple "remove and replace". Sometimes, you need to regrind shaftt ID's and registers AFTER assembly - this is quite common.
THe reply "I don't know" is a dangerous reply when it comes to servicing ANY machine tool applicaiton - especiallly, now when you are now having problems and don't know where you are or where you should be in the first place..
Simply put, if you R&R bearing and now you have "noise", chances are things were done incorrectly or the wrong parts were used.
  #22   Ban this user!
Old 01-24-2009, 11:33 AM
less expensive alternatie to Kluber is Andok C. Bridgeprot used this on their mills for years and some ran 20+ years with the original grease fill
  #23   Ban this user!
Old 01-24-2009, 11:39 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
