I have a bridgeport interact 308 with a tnc 2500. The problem i am having is when the spindle is running backwards the actual RPM is half of the programed RPM. Doesnt matter if its in manual mode, program run mode, M04, or even a tap cycle (Thats the one that kills me.) Is there a prameter that can fix this. I have gone thru the pram list and everything seems to look OK. It has the Flux vector drive if that makes any difference. Thanks, Craig |
| I rarely use the M04 or tapping canned cycle so im not sure how long this problem has been around. I got an optical tach to check the actual spindle speed. In forward with a programed speed of 5500 rpm the actual rpm at the spindle is 4700 rpm. In M04 the following are the results from my test. Any ideas on where to start to correct this problem. Programed Speed in M04 Actual Speed in M04 100 53 200 75 500 398 1000 715 2000 715 3000 715 4000+ Will jump around a little from 700 to 1000 |
| I need to look that up. There was a pile of updates on the 2500 software. They started out with version 3 and settled on version 12. The amount of parameters varied with the version. What version is in your control? I have never installed one of these 308 with the 2500. Nor do I have any book on it. I saw one at a Bridgeport showroom In Worchester MA in 1993 and worked on one that a shop in North Alabama purchased from a school somewhere in the US. They of course lost their parameters. It took a while and I had to get all my service bulletins together but I managed to piece together a set of working,parameters. The reason I mentioned the KTK drive, is because it had 3 sets of transistor/transistor blocks for forward and the same for reverse. If one blew it could not achieve speed in that direction. The question to ask oneself is if the control is happy. If the speed programmed is off by 20% or more, it will not do a feedrate and the "spyder" will be flashing. If the parameters are wrong and the control is happy, it will do a feedrate. This should indicate if the problem is with the control or with the drive. George
| The machine will lock up at higher RPMs. The 'F' on the display will highlight itself and the machine will not feed. I assume this is what you mean by "sypder". If the Override is backed down a little it will start feeding again. Does this indicate a problem with the prameters or the drive? Thanks for all your help, Craig |
| I will have to find a book on the vector drive. If the control sees a spindle speed problem, then the problem may be in the spindle drive. George
#11
Hello George and all bit new to this . Hope you can help .I have been reading some of the emails and see some of you with KTK drives are having problems me too!! inst trip light comes on at power up and spindle kicks round , field ok and SCR's seem ok could really do with a copy of manual for KTK drives . When fixed will post my findings also been fixing TNC155p that was Fun!?. Regards technojunkman |
#12
| How about a email address. All the KTK files are about 10 megs total. George
