Old 07-19-2006, 12:37 PM
wyobmf is on a distinguished road
BP series II Boss retrofit
I recently purchased a series II BP with Boss 4 CNC.
I plan to upgrade to Gecko drives and Mach 3, I am going to try to use the factory steppers. I have a couple questions.
What should I check on this machine beofore I start, Is there an article on how to check backlash, ways and how to adjust the gibs someone could direct me to?
What is a good break out board that works well with mach 3?
What signal does the break out boards use for speed control to the VFD, 4-20 mA?
Old 07-19-2006, 01:11 PM
Hood is on a distinguished road
Pretty hard to check the backlash without having a control as there is not really any way to know how much it actually is. If your control works then you can use a dial gauge to check it.
Dont know of any breakout that has the speed control onboard but I did see a new one from CNC4PC and seem to remember it had quite a few extras on it, possibly speed control was one. You can get several different seperate speed control boards, Homann designs and CNC4PC both do them, usually they are 0 to 10v operation but they may work with your VFD.
I use a PMDX122 breakout and it works well and is reasonably priced.
Hood
Old 07-19-2006, 01:43 PM
I have not bought a VFD yet, I think most of them can be configured to use different types of inputs, I was just curious what people are using. Do you just set the speed before you start the CNC cut? I downloaded a demo of mach 3 and it has a speed sp.
Is there a way you can disengage the stepper motor and check the ball screws that way?
Thanks for the info.
Old 07-19-2006, 01:51 PM
I have a VFD but so far dont have it controlled from the PC. I just have a speed sensor (optical switch) so that I know what the spindle speed is and can then just turn the potentiometer, which is connected to the VFD, to get my desired speed. When funds allow I will get a speed control board and work it through the PC but every time I have been about to get one something else comes up and swallows the funds
The difficulty in just disconecting the stepper to measure the backlash is you dont know how much you have turned the screw. You could make up some sort of a dial I suppose, like on a manual bridgeport but might be a bit of hassle to do that.
Hood
Old 07-19-2006, 05:21 PM
snakebit95 is on a distinguished road
Bob Cambell makes a break-out board that has relays to control activation of the spindle, coolant, e.t.c. Take a look here: http://www.campbelldesigns.com/Combo-board.php
Old 07-19-2006, 05:24 PM
As for a VFD, I have been using one of the Automationdirect GS2 models. Yes, it is China-made.......but has been working good for me so far (2-years and counting).
Check here: http://web6.automationdirect.com/adc/Shopping/Catalog/AC_Drives_-z-_Motors/GS2_(115_-z-_230_-z-_460_VAC_V-z-Hz_Control)
Old 07-19-2006, 05:37 PM
Looks like a nice board from Bob Campbell, seems to do most things required. The CNC4PC board I mentioned above does indeed control the spindle, you will see it here http://www.cnc4pc.com/Multifunction_CNC_Board.htm
I have no experience of either of these boards so cant comment on what they are like.
Hood
Old 07-19-2006, 06:50 PM
The combo board does look nice and it has the analog output, I think I will try one. I have also been looking at the drive mentioned. I just didn't want to buy all the electronics till I was 100% sure my mill is in good condition.
Thanks for all the help.
Old 07-19-2006, 08:42 PM
I have the 1st generation of the Campbell board. Never had any problems and works like it was advertised.
Old 07-20-2006, 07:42 AM
Gold Member
HillBilly is on a distinguished road
I have a breakout board and scheme that allows use of the original Bridgeport stepper drives along with the motors. I still recomend the original drives for driving the original motors because of their current rating, complete documentation and their repairable nature.
This is basically a brain transplant from the BOSS computer and software to a PC running Mach3.
Darek
  #11   Ban this user!
Old 07-20-2006, 08:50 AM
Hillbilly,
Can you give me a schematic on how you wired one of the original drives?
Did you use the original power supply too?
I think the Z axis drive on my machine is smoked, but maybee it could be repaired.
Old 07-20-2006, 08:55 AM
Gold Member
Email me at ashburn@icx.net and I will send you some info.
Darek
