Old 07-10-2006, 09:43 PM
joemac is on a distinguished road
Boss 8 Error code
I have a Bridgeport Series One, CNC, with Boss 8. After the machine has ran for about 2 hours, the axis drives kick out and I receive an error message, error 2000. I can re-set the control and the machine will run for a little while and the same occurs again. I live in Texas and it is well over 100 degrees. Could heat be the problem? Any suggestions? Thanks for your time.
Joe McCulloch
Crawford, Texas
Old 07-11-2006, 08:46 AM
Moderator
machintek is on a distinguished road
Fron the maintenance manual, This is error 2 in group one. It is an internal communications error. Could be wiring, or a device on a board. Check all fans. try running with the cabinet open.
George
