Old 07-10-2006, 05:07 PM
keebler303 is on a distinguished road
making an arc
i have read up on all the code for making an arc but everything I have seen uses R or I J K in the code. I see no way on my MDI to input an R. What am I missing?
Thanks for any help
Matt
Old 07-10-2006, 05:54 PM
mrainey is on a distinguished road
I think the Bridgeport control was limited to IJK to define arc centers.
Software For Metalworking
http://closetolerancesoftware.com
Old 07-10-2006, 06:17 PM
so then do i use the x y z buttons again as the i j k. there are no i j k buttons so i guess that would have to be it. i will go try and report back.
Matt
Old 07-10-2006, 06:37 PM
doesn't work. here is what I was trying
G17 (XY axis) G02 (cw arc) x.xxx y.yyy (endpoint) x.xxx (for I) y.yyy (for J)
can anyone point me in the right direction?
Matt
Old 07-10-2006, 09:17 PM
Did you give it a feedrate?
Old 07-10-2006, 09:26 PM
i didn't explicitly give that block a feedrate but i had a feedrate set prior to that block. g2 and 3 work similar to g1 where it uses the last specified feedrate if one is not specified for that block correct?
i can try giving it a feedrate in the same line tomorrow after work.
Thanks for helping
Matt
Old 07-12-2006, 08:21 AM
DaveinUK is on a distinguished road
Example line from a program for Arc
N20G3X****Y****I****J****F100
The X,Y,Z and N keypad doubles up as the I,J,K and T.
The above works on Boss 5
Good Luck
Dave
Old 07-12-2006, 11:35 AM
so you are saying
N20G3X****Y****X****Y****F100
should get me an arc?
i'll try it tonight.
THanks for the help
Matt
Old 07-12-2006, 08:47 PM
i'm cutting arcs! thanks for all the help. turns out what works is this:
G02 Xx.xxx Yy.yyy XX(I)i.iii YY(J)j.jjj Fff
Matt
Old 10-15-2006, 01:40 PM
jtree83 is on a distinguished road
to use "I" on that control you would press the "x" button twice and the machine will change it to a "I" on its own like for instance if you ar using a "j" value type the "y" button twice and the machine will know that you are entering a "j" value (that is a bridgeprt textron control its old school but its accurate)
