Old 06-30-2006, 04:39 PM
jeromir is on a distinguished road
Unhappy Bridgeport Interact 520/Heidenhain TNC 155 initial parameters
Hi there all,
I have 1987 Bridgeport Interact 520 / Heidenhain TNC 155. It lost all initial parameters (battery miscontact). Would any of you guys who may have identical machine share with me the whole list or point me to where to get it, please ! The original list from the manufacturer is "nowhere to be found".
jeromir
Old 07-01-2006, 08:59 AM
Moderator
machintek is on a distinguished road
When I get back to my office, I will look for an ETS on this machine. It is a British start up procedure that includes a set of generic parameters and data on how to set most of the others, as well as tune drives etc.
George
Old 07-04-2006, 09:50 AM
Hello George,
I'd be most grateful if you could help me on that matter. I wait urgently for your answer.
Jeromir
Old 07-04-2006, 03:46 PM
Moderator
Please give me your e-mail address so I can forward the file as a scan in PDF. I will try to be at the office in the morning.
Jurek
Old 07-04-2006, 05:43 PM
pentium@hot.pl
Thanks you very much.
Jeromir
Old 07-05-2006, 10:26 AM
Moderator
Attached are 3 files, each with a different amount of parameters for the version of TNC155 you may have.
George
Old 11-27-2009, 05:36 PM
Gustavob is on a distinguished road
I need helped
Originally Posted by jeromir View Post
Hi there all,
jeromir
I have the same problem can you help me
mi model machine is 520
TNC 155
Old 12-14-2009, 04:12 AM
moghul is on a distinguished road
hy all i ahve tnc150. it lost automaticly parameters and not going to parameter entering screen. please help me any one
thanks
shabbir moghul
Old 12-14-2009, 11:04 PM
Moderator
If the parameters are lost it will boot up in German saying that the parameters are lost. Pressing the clear button it will ask for the first parameter in German.
George
Old 12-15-2009, 02:46 AM
error in tnc150
hello all
basic problem is that it is not going on parameter entering screen after colearing the error by ce. no key i sfunctional after this.
  #11   Ban this user!
Old 08-30-2010, 05:01 AM
minhas1986 is on a distinguished road
Thumbs up CNC T #echnical Help
thanks
shabbir moghul
Shabir Sb.
1st of all remove the bettery from the controller and then switch the machine in ON stat and then machin will go on parameter position and languge will chang in Germen. Clear all the messges with CE button and after clearing all messges put the parameter manualy or by computer.
you can mail me at my adress
minhas1986@gmail.com
