Old 06-24-2006, 01:19 PM
split63 is on a distinguished road
Bridgeport BOSS 6 X-axis Belt
Where can I find the X-axis belt for my Series I BOSS 6.0 CNC Rigid Ram Mill?
What's left of the belt seems to have 44 teeth.
THanks,
Old 06-24-2006, 10:15 PM
Kevin Taylor is on a distinguished road
Try WW Granger they have gilmer belt's also some hotrod engine supplyer's may have what you need try gates on the web googel gilmer or timing belt's BPT part's on ebay has lot's of nos bpt part's also Good luck Kevin
Old 06-26-2006, 10:23 AM
Exclamation closer
I have not had much luck find the belt for the X-axis, however it appears the the Z and Y axis have been replaced with goodyear betls. Here are the Goodyear part numbers
Z: 270H075
Y: 240H100 (48 tooth)
I decode this as (number of teeth/10)(H series)(Width in inches)
So this would meand that the X axis should be:
X: 220H100. (44 tooth)
I still don't know what the bridgeport part number is. The 6.0 machine went to the 2:1 pulley, so its a different belt than on the 5.0 and earlier machines.
Note also that the tooth spacing is 0.5" and the belt thickness, including a tooth is 0.16".
(UPDATE) After talking with Bridgport, they provided the following original part numbers:
X Axis belt: 11652116
Y Axis Belt: 11652117
X Axis Counter Belt: 11770271
Old 06-26-2006, 06:29 PM
Found what I needed at McMaster-Carr
