Old 06-05-2006, 05:54 PM
split63 is on a distinguished road
Question Tramming Spindle Square
Has anyone used this spindle square?
What do you think?
tramming spindle square
This seems like a good idea. When you make an adjustment, you know right away if your on the money or not and can quickly reach perfect. With the other single dial indicator methods, you need to rotate the spindle and take another measurement.....make an adjustment, rotate the spindle, take a measurement, make an adjustment.....etc.
Thanks,
Old 06-05-2006, 09:36 PM
NC Cams is on a distinguished road
Should work fine - providing you check to make sure it IS SQUARE and STAYS SQUARE before/while you use it.
I"d prefer a wider spread between the dials for a finer squareness resolution.
Old 06-05-2006, 09:50 PM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
since you are spining it around a circle I don't think it would mater if it is square. Unless of course the POS is flexing then it would be bad.
I think it would be more critical if the bearings or alignment in the spindle bore is true or the runout (which is the biggest factor) is too large.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Old 06-05-2006, 10:57 PM
One of Many is on a distinguished road
I wouldn't trust it within .005 on a 1/2" shank. So what if the indicators read the same. If you still need to turn the spindle to verify the assembly is gripped true to its calibrated plane, then why bother. I doubt it will gain you much precision considering its span either.
It's got bling! Looks twice as precise with 2 dials though don't it?
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 06-05-2006, 11:12 PM
All a bit academic seeing as how this is copied right from the ad.
"Super Blow Out Sale! Expires 02/29/04"
Old 06-06-2006, 11:02 AM
miljnor's Avatar
S.N.A.F.U.
But the only way that the plane can be out is too have the spindle itself missaligned, i think.
if the shaft was bent on the tool or the too dials read differently, it wouldn't matter as long as the readings didn't fluctuate as it spins on its axis.
The only problem I could see with the tool is if it flexed as it spins. And even a 1/2" shaft isn't going to flex under the pressure of a dial indicater.
And as far as how far apart the indicators are thats just a math problem. you can arrive at whatever runout you want if you do the math. I would personally replace the dials with .0001" reading ones. But another thing to consider on the distance is that alot of home mills don't have tables that big (I think the one on my mill is 6"x25" aprox).
While this is true for the lower price you can still buy them at regular price. But personaly I don't think it would take much to make one with your own dial indicators. Then you could make it as wide as your comfortable with.
thanks
Michael T.
Old 06-06-2006, 12:00 PM
phil burman is on a distinguished road
Sorry split63 but I think you would have to be crazy to buy one of these. How many mills do you have how often do you tram them and what does USD 140 (on sale) mean to you.
As somebody else pointed out you would have to check the instument was square first and how would you do that. You can't use the mill because you not sure if it's square in the first place. Also how do you now that you have mounted it with its shaft parallel to the spindle axis. No mention in the add about precision. Whats wrong with rotating a single instrument, zero scope for error.
You guys must be short of something to spend your money on.
Regards
Phil
What do you think?
Thanks,
Old 06-06-2006, 12:59 PM
Mcgyver is on a distinguished road
gotta agree with Phil, based on 140$ and the duty cycle that puppy would have, a Starrett mic'd be a bargain at 50k
Old 06-06-2006, 02:37 PM
If you want inexpensive it is difficult to beat a length of 1/2" round bar, turn a point on one end, file and polish to a tiny ball tip, bend to a Z so when it is held in a collet the ball tip is perpendicualr and sweeps out a 10" or 12" diameter circle then get the trusty feeler gauges between the tip and the table. ALign the spindle to within .001" over the sweep of the tip.
Old 06-06-2006, 02:49 PM
Steve@Reliance is on a distinguished road
Once you have learned how to set up a head with an indicator, it can be done in about a minute. I use a mini mag base and a test indicator so the dial faces up. sometimes on complicated one off parts, I have had to set the head 1/2 doz. times a day. You just get used to it. Looks like a tool a rookie that dosen't feel like learning would be interested in.
  #11   Ban this user!
Old 06-06-2006, 02:52 PM
Not enough Bling. Do the feeler gauges come with a digital read out.
Phil
Old 06-06-2006, 03:44 PM
miljnor's Avatar
S.N.A.F.U.
mine do, but I think the batteries are low because it never changes! one of them reads .001 constantly! Maybe thats why they were so cheap! they are broken!
hehehe
thanks
Michael T.
