Old 03-23-2006, 08:53 PM
justartingout is on a distinguished road
EZ trak Y DAC overflow
I am currently enrolled in a Technical College for Machine Tool Technology. I am a workstudy for my shop instructor, and one of my duties as such is to see if I can fix machines when they break, but this ones got me stumped.
It was working fine one afternoon, but the next day when we tried to home, the Y motor moved faster than normal for a couple inches, then the Y DAC overflow error came on the screen.
I read the thread about EZ-TRAK SX not reading the hard drives, and it was mentioned that it may be the BMDC board. We have another EZ trak that requires an external keyboard to press f1 on startup, but it works fine after that, and this one was opted to be the donor. After unplugging both machines, I removed the BMDC from the probematic one, and replaced it with the donor, it then homed the Y, but gave me the same problem with the X. After putting the original BMDC into the donor macine, it also overflowed in the Y. Now, both BMDC's are in the original machines, and the first machine overflows in the Y, while the donor is back to normal.
Any help on this would be greatly appreciated, and if you need more clarification, let me know.
Thanks, Dan
Old 03-24-2006, 07:37 AM
Moderator
machintek is on a distinguished road
A DAC overflow means the control asked the axis to move and did not see a response. In other worked you have a bad position loop. This usually means a bad encoder. But it could also be a bad cable or a bad connection somewhere and/or a bad BMDC (but you eliminated this).
FYI: A encoder can be good and count but a machine can still not home if the marker pulse has stopped working in the encoder. The machine looks for the switch and then the marker pulse. If you start the homing process with the machine on the home switch, it will back off and come back on the switch. If it never reverses direction after coming off the switch, the switch or wiring is defective.
If an encoder shorts out or a cable shorts out on a pre-cutler hammer control machine, it will fry the L1 on the BMDC. Starting with the cutler hammer control, there is a circuit breaker on the 5VDC so this should not happen.
If you know how to get to DOS, with a full size keyboard, go to the root directory, type in PFM.exe and return (enter), cursor down to tuner, hit enter again, and you will be in a tech screen that is very helpful in diagnosing problems.
The other machine needs the CMOS battery replaced. It it has the half size mother board, it may have a Dallas Real Time Clock chip instead. That also can be replaced. Google it.
George
Old 05-19-2006, 03:04 PM
DGeoLab is on a distinguished road
Hi to all,
We had the same problem here. I found that the lamp in the encoder
had burned out. When I replace the bulb - that problem went away.
Now unfortunately I get and error when trying to home that "power on failed"
Any Ideas?
THanks,
David
Old 05-20-2006, 09:30 AM
NC Cams is on a distinguished road
Must be contageous. Check this out for more info with identical problem:
http://www.cnczone.com/forums/showthread.php?t=20721
Old 05-20-2006, 09:41 AM
Al_The_Man's Avatar
had burned out.
Holy Cr*p, how old are those encoders?
I haven't heard of lamps in encoders since the Ferraniti-Packard days.
Old 05-20-2006, 12:11 PM
BTW, the machine that you have to push the F1 on may have a CMOS battery going bad.
It may also have a HDD/FDD card going south. IF the HDD/FDD goes bad, the M/B can get hurt as well - happened to ours.
If you lose the M/B, you're in for a ration of grief that is frustrating and potentially expensive... Been there, done that...
Old 12-22-2008, 03:42 PM
hotrob1 is on a distinguished road
Lightbulb Motherboard
I've heard of people replacing the motherboard and resolving the "DAC overflow" problem. Is this common?
-Hotrob1-
Old 12-22-2008, 07:41 PM
Moderator
DAC overflow is a condition where the control calls for movement of an axis and does not see it move.
NOT mother board related.
George
Old 12-29-2008, 09:33 PM
hdjeffrey is on a distinguished road
I'm having the same problem on ezpath lathe
coming back from christmas vacation ,fired up lathe and z dac overflow! read in some threads to swap servo motors and see if the problem followed the motors, it did not! then swaped out limit switches ,still the same , i guess its a process of ruling things out !
Old 12-29-2008, 09:43 PM
Read between the lines in post number 8 - limit switches have nothing to do with encoder outputs.
BIgger hint - check encoder output with an oscilloscope.
BIGGER HINT YET. make sure the encoder cables pin out from servo back to AXISBOB card.
IF you do encoder check with scope at AXISBOB, you do all checks at once.
If encoder input is going to the BMDC, that could mean BMDC service is needed. ONly EMI does that.and it is somewhat costly.
If you eliminate problems by swapping out the wrong stuff, you may not get results anytime soon. Swapping of servo motors does nothing to validate cables or internal wiring issues - repeated cable flexing and /or oil soaked cables does nothing for their durability over time. Even externally "pristine" wiring that has had the hell flexed out of it may not still be conducting properly. Better yet DO A FULL PINOUT OF THE CABLE UP TO THE AXISBOB ribbon connector into the BMDC.
ALl this pinout crap takes a while but you can figure it out.
  #11   Ban this user!
Old 01-07-2009, 12:33 PM
Dagon is on a distinguished road
had the same problem, wasn't the encoder or motor, cables ect.. finally swapped out the x and y drives, and the problem followed the drive.. according to Hardinge, you can swap x and y, but not the z drive for troubleshooting. Once the problem is found, you should return them to original positions as they are tuned for that axis..
Anyway, went to hardinge and after a bit of a search, found and purchased a new drive amp and all is well.
Hope this helped.
  #12   Ban this user!
Old 01-07-2009, 02:16 PM
As I recall, any error that is associated with the amp can come back to the BMDC via one singled OR'd signal from any of the amps via the one error path. THis is usually thru wire 28 fed to pin JP 10-1 on the AUXBOB card. Check your schematic for detials.
THis means that ANY amp error, be it over volt, over current, move asked for/not made that occurs due to an amp fault of ANY kind will be displayed as DAC overflow. In light of the easy of changing/swapping amps, I"d be inclined to swap amps first with ohter stuff to go thru the musical chairs routine thereafter.
