Old 02-28-2006, 04:58 PM
*Registered User*
Pat2000 is on a distinguished road
BPort DX II cable to PC
Can someone please confirm the pin-outs for a cable connecting the Bridgeport EZtrak DX II (25 way D-type) to a PC serial port 9 pin D
I have been told to wire as follows but I'm a little un-certain??
25way
1---------------1 on 9pin connector
2---------------2
3---------------3
7---------------7
4--link--5
6--link--20
I presume the links are inside the 25way D-type?
should 2 go to 2?
should 3 go to 3?
what should I do with the screen on the cable? link to 0v? both ends??
I will be using EZutils on the PC, the main use of the cable is to back-up in a quicker way the programs on the m/c.
thanks in advance,
Pat
Old 03-01-2006, 02:41 PM
*Registered User*
I've just tried this config today but no joy, I don't think pin 1 is wired inside the Mill, can anyone point me in the right direction
Old 03-01-2006, 03:06 PM
Al_The_Man's Avatar
Pin 1 in the 25pin is not always connected try this link
http://www.cadem.com/ncnet/dnc-detai...t-boss-8-9.pdf
Old 03-01-2006, 03:17 PM
*Registered User*
Thanks a lot for that Al, will try.
Pardon the Q but whats the basic difference in 'full handshake' and 'null modem'
I just want the link for file transfer - is one for 'drip-feeding' ?
I'll study form on your link, appreciate your help
Pat
Old 03-01-2006, 03:43 PM
Al_The_Man's Avatar
Null Modem cables usually have full handshake, on the 25 pin side, pins 4,5,6,8 & 20 are concerned with handshake these cross over to the appropriate counter part pin on the other end, 4 would go to 5, 5 would go to 4 etc, when jumpered out it means hardware handshake is not in effect, many systems just use software code handshake.
