Results 1 to 3 of 3
Thread: Advice Needed Regarding Bridgeport Interact Axis Motors
    Dec 2003
    UK
    It says on the spec plate on the motor, amongst other things ... Perm Magnet DC Servomotor - Volts 140, Pulse Amps, 50.
    Could somone explain to me what pulse amps are ? If they are the same as normal amps that would meen that this single axis motor is consuming about 6kw of power. I'm sure that cant be right!
    Dom
    http://www.ukrobotics.com/projects
    Dec 2005
    I suspect that "pulse amps" means momentary surge current. In the motor you're talking about, this condition occurs at locked rotor stall. This is also why locked rotor is limited to a 1% or so duty cycle.
    And, yes, you do consume LOTS of power when you stall PMDC motors - and you can also create LOTS of SMOKE. This is why a servo amp with a properly working and configured protection circuit are critical to their operation.
    Dec 2003
    UK
    Made some phone calls today, found out that 50amps is the peak rating, 8.6 amps continious.
    Dom
