Old 01-21-2006, 07:28 AM
zcases's Avatar
zcases is on a distinguished road
Series 1 speeds/feeds
I am curious what types of speeds/feeds people are getting with Bridgeport series 1 iron. I know there are a ton of variables............just curious to hear some different experiences, in, say..........6061 aluminum with a 1/2 cutter.
Scott
Old 01-21-2006, 08:18 AM
Karl_T's Avatar
Karl_T is on a distinguished road
I'm a "ballpark" kind a guy. I'd start this at 2000 RPM and 15 ipm. And coolant to keep from welding AL on the cutter. Then watch how it cuts and adjust the feed and speed.
DOC is the main variable to change between a really rigid machine and one that is less so. I'd make the first pass at 0.100".
Karl
Old 01-21-2006, 01:20 PM
Moderator
machintek is on a distinguished road
I used to make microwave parts with my BOSS 9 in Aluminum. I used OSG end mills typically 1/2 diameter but with a fast helix specifically for aluminum. This is going back almost 20 years so technology may have changed. I believe I was using flood coolant, with 2500 RPM and feeds about 24 IPM. I was using canned cycles for hogging out cavities with depth passes in increments of at least .200 inches. I was trying to pay the bills.
George
Old 01-21-2006, 03:54 PM
zcases's Avatar
Thats encouraging. I've been really baby-ing this thing, similar feeds/speeds but very shallow on the depth. Embarassingly only 0.020 - 0.050. Now I'm getting into some 3d contouring and I'm getting impatient. Thanks a lot.
Old 01-22-2006, 01:05 AM
Gold Member
jdelaney44 is on a distinguished road
With pretty crappy cutters (old 4 flutes) I am doing 10 - 15 ipm with a ~.5 cutter and a 0.050 depth of cut. I need to get my 6 flute center cutters sharpenned. They work better.
Anything faster and i don't care for the finish.
-jd
John Delaney
www.rwicooking.com
Old 02-09-2006, 10:37 PM
Zombiestomp is on a distinguished road
I have been using software from predetor software inc. called Machinist tool Box .
Has Excelent Speedand feed calculator. Its way more accurate than the one that comes with the dx2 software . the demo is available from http://www.shopfloorautomations.com/...t_tool_box.php
