Old 01-16-2006, 02:35 PM
Lasershop is on a distinguished road
V2XT wont load program
Machine is up and running finally. Everything seems fine except when I send a file (load a program from the hard drive) it used to take just a few seconds but now it hangs with the prompt "loading to DNC" and thats it. Anyone had this problem? It will sit there all day doing that. Reloaded all the software with a brand new hard drive but made no difference.
Old 01-17-2006, 07:31 PM
Moderator
machintek is on a distinguished road
How big is the program? If it exceeds the limit of the BMDC (about 256K) it will try to DNC but is faulting as you have not set up the DNC. Check the operating manual.
George
Old 01-26-2006, 10:55 AM
George
It was just a small test program to set up the machine. I did an F7 load and that worked. After that my normal way of loading works every time. Weird, but now it works fine. FMDC
