Old 12-19-2005, 04:46 PM
unterhaus is on a distinguished road
can I get a 13 tooth timing pulley
for a BP series II Z axis drive? It would be an H series pulley (1/2"), but nobody makes a 13 tooth, I guess bridgeport had them made.
Old 12-20-2005, 01:27 PM
Kevin Taylor is on a distinguished road
Try bptsrus on Ebay or maybe one of the race car drysump people weaver,stef's moroso ect. Would one off of a Boss6 work ?
Old 12-20-2005, 03:57 PM
I don't know when the z drive went from the knee to the head. I believe any mill that has the drive on the head uses the same 13 tooth pulley. I'll have to ask bptsrus if they have them.
Old 01-09-2006, 10:43 AM
I couldn't properly explain to bpartsrus which pulley I'm looking for. Did you have a lead on one off of a Boss6? Anyone have any idea where I can find this pulley?
Old 01-09-2006, 03:07 PM
lvanduyn is on a distinguished road
BP 13 tooth pulley
Unterhaus...
I had the same problem with my series I. The Z axis motor and pulley were missing. I bought a 10 inch piece of 13 tooth stock and made my own pulley with the taper lock hub like the other axes. I think I still have part of the piece if you are interested in making your own pulley..
Larry...
Old 01-09-2006, 06:02 PM
damae's Avatar
damae is on a distinguished road
My Series I BOSS3 has the quill-mounted motor, but it uses a 26-tooth pulley...
Old 01-11-2006, 01:02 AM
Doh! I never thought of a 26 tooth pulley, wonder if it would fit. Larry, I definitely would be interested in the pulley material.
Thanks,
Eric
On edit, I looked at the mill. Clearly there was a 13 tooth pulley on there since the belt is slightly too tight with a 14 tooth. It's not clear that the belt would have clearance with the head for a 26 tooth pulley. Also, I've never figured out how to get that belt in there. Looks like you have to remove the spindle?
Old 01-11-2006, 01:05 AM
ViperTX is on a distinguished road
So, we drove ourselves nuts for a 13 tooth pulley........geesch....
Old 01-11-2006, 01:39 AM
ViperTX, in the process of driving yourself crazy, did you find a 13 tooth pulley?
Old 01-11-2006, 11:11 AM
Moderator
machintek is on a distinguished road
In a BOSS 6 book the Z motor pulley is part number 12770133. Call Hardinge or a Bridgeport dealer and see if one can be obtained.
George
