Results 1 to 6 of 6
Thread: Bridgeport head stuck.
    Jun 2012
    United States of America
    I just got a Bridgeport series 1 with a 2J2 head. To move it I tilted the head 60 degrees to the right. The head will now not go back into position. At about 40 degrees it binds up and will not move any farther.
    Thanks.
    Jul 2009
    Quote Originally Posted by dave86 View Post
    Thanks.
    It just happened to my turret mill today. Anyone here have any idea on what's wrong The head is tilted at 45 degrees and I cannot tilt it back to 90 . The adjustment bolt became so tight and I cannot move it anymore either up or down
    May 2004
    Apply twisting force in the appropriate direction while turning the adjustment screw. 2 man operation.
    Then disassemble and clean and reassemble.
    Machines require periodic cleaning and maintenance.
    http://www.kirkcon.com/
    Jan 2006
    The studs that hold it in position may be to blame. If too loose, they can interfere with the housing and get jammed up in the castings. They can also "cam" into the slot inside and prevent it from moving. Try loosening the bolts only enough to get it to move without them having any extra wiggle. If it gets tight, try tapping the studs with a mallet to make sure they are not bound up.
    Matt
    Jul 2009
    Quote Originally Posted by keebler303 View Post
    Matt
    You are right Matt, one of the T bolt was stuck. I tapped it and now it's okay
    Thanks Mate :-)
    Jan 2006
    Quote Originally Posted by pearldiver View Post
    Thanks Mate :-)
    Good to hear!
    Matt
    1. bridgeport cnc x axis stuck
      By troysk8 in forum Bridgeport and Hardinge Mills
      Last Post: 02-27-2011, 12:07 PM
    2. Need Help!- Stuck opening mill head
      By cnczoner in forum Benchtop Machines
      Last Post: 02-25-2010, 09:58 AM
    3. Stiff quill, stuck collet on M-head
      By ogesII in forum Bridgeport and Hardinge Mills
      Last Post: 11-21-2009, 01:01 AM
    4. Need Help!- Bridgeport Series I Boss Z axis stuck!
      By dynamotive in forum Bridgeport and Hardinge Mills
      Last Post: 10-21-2009, 01:31 AM
    5. router head getting stuck in z postion?
      By ilovewood in forum Commercial CNC Wood Routers
      Last Post: 01-24-2007, 06:10 PM
