Results 1 to 5 of 5
Thread: Bridgeport 2J head rebuild
    Jun 2012
    I am working on a rebuild for a 2J head. The operator complained about noise and vibration. After pulling the head and opening it up it is full of green plastic. Is there a rebuild kit for this that contains the necessary items?
    Mar 2012
    I don't know what that is, but you can get rebuild kits from H&W Machine Repair and they are very knowledgeable and can probably answer your question. Bought my ball screws and some other BP parts from them recently and found them a great company to deal with. H&W - Parts for Bridgeport Mills, New & Used Machinery, DRO's, Power Feeds
    Jun 2012
    Thanks this is what i needed 2hp Adjustable Motor Vari-Disc Assembly
    Moderator
    Nov 2004
    A heads up. The original heads were 1.5 HP and later they became 2 HP. The motor shafts are a different diameter.
    Originally both came with thin black inserts that were epoxied in. Kits are available for this but I do not recommend them. You would have to glue these in with precision so the disc runs true in 3 dimensions or it will vibrate.
    The front vari disc still is made this way. The rear now comes with a thicker green insert. This is not replaceable.
    When replacing these, I usually replace both front and rear discs, plus the belt and the three bearings in the front. This assures a head that will not need further attention in that area.
    George
    Jun 2012
    ordered the new varidisc assembly from H&W all is well now. smooth as silk
    1. New Machine Build- Head Rebuild
      By MSGMachine in forum Bridgeport and Hardinge Mills
      Last Post: 03-07-2010, 03:03 PM
    2. Bridgeport J-Head Rebuild Question
      By Rockabye74 in forum Bridgeport and Hardinge Mills
      Last Post: 05-26-2008, 08:01 PM
    3. Bridgeport variable speed J-head rebuild (help anyone!)
      By SMG in forum Bridgeport and Hardinge Mills
      Last Post: 11-22-2006, 10:23 AM
    4. 2J head rebuild, What did I miss??
      By Stillearnn in forum Bridgeport and Hardinge Mills
      Last Post: 10-25-2006, 03:21 PM
    5. Bridgeport J-Head Rebuild Kits?
      By jdelaney44 in forum Bridgeport and Hardinge Mills
      Last Post: 05-28-2005, 01:24 PM
