Make sure the hot or fantom leg from the phase converter is not connected to the main transformer. Check your voltage coming out of the main tranformer. You may have to move the feed wire to a different set of post to bring the transformer out put into spec.
Russ F. out
LinkBack URL
About LinkBacks
