Results 1 to 4 of 4
Thread: thread mill
    Jun 2004
    thread mill
    hi , anyone ever done any thread milling on an eztrak ? i have a job coming up with 128 3/4-10 threaded holes in 1" plates, did you use featurecam to program or something else?
    thanks
    r brintle
    Jun 2011
    Any helical thread milling will require you to have 3-axis control. Not just 2 1/2.
    First, check to see if your machine has this capability. Then, it's just a circle with a Z. (pitch)
    Jun 2011
    bavaria
    Or better many circles, because some easier controls can't make more than a circle per line.
    Jun 2011
    Quote Originally Posted by uli12us View Post
    You're correct. The cutter path would need a line for each 360 degree circle @ a depth (or height) of your thread pitch.
    Plus, you'll need to find a thread mill with that proper pitch.
    It would be easier to create a sub routine for the helical moves and use this for each hole location.
    Allied makes a 3/4"-10 Solid Carbide Threadmill with 1.6" of cut depth. (TMUK0750-10XL) that would only require a lead-in, one revolution, and lead-out.
  1. Thread mill this?
    By Shotout in forum CNC Tooling
    Last Post: 10-30-2009, 09:38 PM
  2. Thread mill help
    By dpark1 in forum Mastercam
    Last Post: 07-19-2009, 03:25 AM
  3. Thread mill external NPT thread
    By cutting edge in forum General Metalwork Discussion
    Last Post: 09-15-2008, 09:33 AM
  4. THREAD MILL
    Last Post: 03-06-2008, 06:02 PM
  5. Thread mill in XR2
    By DSL PWR in forum OneCNC
    Last Post: 01-16-2007, 01:40 AM
