Since it can do canned cycles just fine, it is probably not a parameter, rather your CAM program is chopping the moves into tiny little moves, and it is trying to accelerate at every corner rather than a smooth calculated arc.
50 ipm is pretty fast for that era servo amp. The control doesn't care but the servo amps cannot always do it. You could up the accel decel parameter, but if the canned cycles work, that really isn't the issue.
LinkBack URL
About LinkBacks
